09-18-2011, 02:20 AM | #1 |
235
Rep 1,334
X3 Transmission
When driving normally I can feel the loss in forward movement during the gear shifts. So your head kinda rocks back and forth a little bit. Does your X3 behave this way? On my M3 with DCT .. the shifts are so fast and smooth ... it's smoother than this automatic transmission..
E92 M3 - DCT - 20" BBS LM-R - KW Clubsport - Akrapovic Exhaust - Powerchip Tune - Arkym Aero Kit - HID Halo |
09-18-2011, 02:50 AM | #2 |
67
Rep 1,041
Mine certainly does that at light throttle (normal driving). I think it's the electronic throttle reducing engine torque during each shift. It's probably set up that way for best economy. Just using more throttle seems to override "the loss of forward movement" as does using Sport Mode with its much higher and faster shift points. Of course that may result in more acceleration than you want in "normal" (meaning slow) traffic, and certainly won't help your fuel consumption.
09-18-2011, 03:22 AM | #3 |
235
Rep 1,334
Guess I feel a little better, it's still a bit annoying. Thanks Lotus.
09-18-2011, 07:57 AM | #4 | |
67
Rep 1,041
*For anyone who cares: the slightly "jerky" downshifts during deceleration keep the engine (and alternator) spinning fast enough to provide a very high momentary battery charge rate when the throttle is closed. This helps slow the car down and supplies "free" energy to the battery, hence the name "Brake Energy Regeneration (BER). |
