Anyone know about thrust Arm bushings?
09-14-2011, 06:07 PM | #1 |
See Me Fly By In A 330i
55
Rep 255
Drives: AlpineWhite 330i 6-speed
My car just went to the dealer and found out that my thrust arm bushings are cracked, can i get get high performance bushings that last longer and where? thanks for the help in advance
E90 330I
10-14-2011, 12:35 PM | #4 |
733
Rep 10,105
Not sure if there are any performance bushings out, but know that if you do a poly-based bushing theres a higher tendency of vibrations.
Upgrade to the OEM M3 if you want something other than stock. We do these all the time and can put together a package for you if you'd like (stock, or M3) Let me know, we sell OEM parts and have a BMW certified master tech on staff |
03-22-2015, 04:15 PM | #5 |
Guest
Rep n/a
Drives:
How do you know you really need bushings? I brought my car in for the recall because I was having a battery drain - car kept not starting - headlights were left on like 10 minutes and no start. Next time left the trunk open maybe 20 minutes - no start. Didn't use the car for 3 or 4 days - no start. Mechanic said no start from non use & charging system good but I figured something had to be draining it faster than normal & figured the tail light recall was it. So I bring it for the recall - and they also did the airbag recall at the same time - they had my car 4 hours - Claim they did a health inspection and found that my bushings were cracked. Never had any steering problem before & just had the car inspected by a private guy 4 months ago.
So how do you know the bushings are bad? Wouldn't the steering be affected? Unless the SOB did it while he had it for the recall. Another issue - now the headlights - not the tail lights which were part of the recall - but the headlights - are suddenly loaded with moisture which was a problem I never had before. What the hell were they doing in my headlights? Then I look on the technician recommendation and its says I need flashes. Funny but I didn't need them before I brought the car in for the recall - Also said my fuel pump needs to be changed Now I had a hard time starting the car - friking again - but this time it is different. Before it was a battery drain & a jump started it up. It is different now - I had to floor the gas while cranking the starter. Shit. What the hell did they do to my car? I bring it in for the recall thinking that will put an end to the non start - now I got another non start problem - this time related to fuel - condensation in the headlights which I'm sure will lead to electrical problem and they claim by bushings are cracked - price quoted $550 plus another $500 for the fuel filter. Bastards even messed with my wipers which are only a year and half old saying I need new blades - I bet they took off my good ones and changed them with old ones. Long Island dealers - there aren't any you can trust - Thoughts? |
