Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Cobb Stage 3 (Alpha) - vids
      09-13-2011, 09:49 PM   #1
dzenno
273
Drives:
Thumbs up Cobb Stage 3 (Alpha) - vids
At an airfield event, recorded these two
Next up I'll be stacking a JB4 on top to add a tiny bit of extra boost progressively up top when meth is flowing...AFR is a perfect 11.5 all the way through and it hits that target immediately at the kick of throttle...no wild upswing/downswing that I used to experience and couldn't 100% tune out on either procede or the JB4...I don't want to run 18psi all the way to redline flashed as that leaves no room for so called meth safety..
I consider this flash/piggy (procede or jb) combo a very potent one as you have "direct" timing and fuel control which is 100% predictable and then use a piggy for progressive boost and meth safety where required...obviously that'll be "the thing" until a flash like Cobb can deal with all three
As you can see, NO MORE MISFIRES UP TOP!!!
      09-13-2011, 10:03 PM   #2
mithiral67
That guy
mithiral67's Avatar
117
Drives: 2015 Cayman GTS
yep
      09-13-2011, 10:13 PM   #3
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
sweet!
Btw, the cobb is installed Let the games begin
E90 LCI N54 6AT
      09-13-2011, 10:15 PM   #4
Q4P
Q4P's Avatar
Drives: Too Much
fu**, your car's fast
2jZ + RB26 + 4G63 + LS9 + N54 =
      09-13-2011, 10:15 PM   #5
onesuperboi
onesuperboi's Avatar
Drives: '08 e92 335i COBB 4.01 Stage 1
Sorry for being OT, but how did you resolve your misfires??? I remember when you running a particular tune that it always misfired. So, was it tune related or something with your hardware?
      09-13-2011, 10:24 PM   #6
dzenno
273
Drives:
thanks buddy..this is running 18psi@midrange, 16psi@6k, 14psi@6.5k, 13psi@7k rpm, pump gas with a slight bit of meth flow as it was near the end of the tank...IMO, its the ideal base tune to stack more boost on top progressively when meth flow is there
Wish ATR was already available and Cobb had a way of doing progressive meth but I have no problem using a piggy such as JB4 as a mini ATR and setting up a custom map6 with a meth flow based boost additive to lift the boost curve towards redline a bit more aggressively when "sufficient" meth is flowing and even further up when both meth and race gas are in there...
hitting the strip tomorrow, time to break stuff, hopefully just numbers not parts this time lol
      09-13-2011, 10:27 PM   #7
dzenno
273
Drives:
I turned that shit off LOL
its still up in the air what it really is but I politely asked Cobb to just turn off misfire detection for me to see if it really is an "actual" misfire (loss of power, black smoke, backfires, etc) or something diagnostic tripping a false misfire code...lo and behold, they were kind enough to provide me with that feature in this map and the car doesn't misfire at all...on many platforms misfire detection itself has to be tuned so its less sensitive or turned off as it gets in the way of high HP tuning due to it being adjusted to stock power levels...
      09-13-2011, 10:27 PM   #8
Q4P
Q4P's Avatar
Drives: Too Much
Awesome, when the Cobb is able to do all of this it will be nuts!
      09-13-2011, 10:30 PM   #9
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
its still up in there what it really is but I politely asked Cobb to just turn off misfire detection for me to see if it really is an "actual" misfire (loss of power, black smoke, backfires, etc) or something diagnostic tripping a false misfire code...lo and behold, they were kind enough to provide me with that feature in this map and the car doesn't misfire at all...on many platforms misfire detection itself has to be tuned so its less sensitive or turned off as it gets in the way of high HP tuning due to it being adjusted to stock power levels...
If that's the case, how about them creating an alpha "stage 3 race" map for you?
Then you don't need to use the JB4 to sustain boost top end.
BTW, I talked to Terry earlier today, he's open to the idea of creating a custom meth failsafe to be used on a flash tune.
E90 LCI N54 6AT
      09-13-2011, 10:30 PM   #10
dzenno
273
Drives:
trust me this stage 3 tune that's basically the stage 2 tune with load extended to 6k rpm for now is already nuts with RB spice on top
      09-13-2011, 10:32 PM   #11
dzenno
273
Drives:
I have a map that runs 190 load to redline...that's 19-20psi...in all honesty I'm too chicken shit to run it I'd rather run this 180 load to 6k and then raise boost when meth is there, just hard letting go all the way lol
      09-13-2011, 11:30 PM   #12
blisstik
blisstik's Avatar
151
Drives: E92
So you can't keep 180 load to redline while raising boost to 19-20psi with JUST Cobb?
Your top speed is just awesome, I think I saw you hit almost 160mph!
      09-13-2011, 11:38 PM   #13
dzenno
273
Drives:
Can't do it "based on input from a meth flow sensor"...you can go 190 load to redline if you feel your meth kit is failproof but i don't trust any meth kit THAT much
I let off at 260kph as it was getting scary! fastest I've personally EVER gone in any car
      09-14-2011, 01:09 AM   #14
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
great vids dzenno! any vbox times yet? you must be really glad to have finally vanquished the missfire troll!
      09-14-2011, 01:14 AM   #15
blisstik
blisstik's Avatar
151
Drives: E92
So what would Cobb need to do in order to have what the piggys can as far as having progressive boost based on meth flow? I know I'm missing some basic stuff here so hear me out.
      09-14-2011, 01:34 AM   #16
tibra1
127
Drives: 2011 ZCP M3 - 2007 335i crashd
It just looks fast b/c of the km/h speedo.. totally jking..yea that thing pulls like a train..very nice
      09-14-2011, 02:16 AM   #17
Mahhvinn
EUROPROJEKTZ
Mahhvinn's Avatar
Drives: backwards
2008 E90 335i  [7.00]
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke
      09-14-2011, 07:05 AM   #18
dzenno
273
Drives:
Debbie Downer is here everyone lol
      09-14-2011, 07:08 AM   #19
pHo_e92
pHo_e92's Avatar
32
Drives: SGM e92
2008 BMW 335i  [7.26]
2000 BMW 323i  [6.00]
1997 Honda Civic HB  [10.00]
2007 BMW X5 4.8  [10.00]
dzenno if you are going to cayuga today, i'll probably head down there also seeing as i live 30mins away, would love to see that beast run.
08 335i | Space Gray | Burl Walnut Wood Trim | Sport pkg | Premium Pkg | LOGIC7 | Navi | Comfort Access
| COBB | Injen DCI | Active Autowerke | Sonic Tuning | E92 Lighting | ER | HKS | BMS | Ground Control | Vortex Tuning |
      09-14-2011, 07:09 AM   #20
dzenno
273
Drives:
They just need time to do it and who knows if that's even the best way of doing it at this point..maybe we're just accustomed to doing it that way as we don't know any better at this point
      09-14-2011, 07:17 AM   #21
enrita
enrita's Avatar
Sweden
161
would be cool though to see how that one goes with race gas
      09-14-2011, 07:29 AM   #22
dzenno
273
Drives:
For sure man I just need to work up the balls for it
