Removing interior trims for wraps --tools???
09-13-2011, 04:45 PM | #1 |
43
Rep 1,071
I'm researching on what is needed for interior wraps, any expertise in removing the interior will chime in please, will this tools be enought for the jobs -->>
http://www.ecstuning.com/BMW-E92-335....0l/ES2222289/ I'm just looking to do basic interior c/f trim wraps. Thanks |
09-13-2011, 06:44 PM | #3 |
Cuba
81
Rep 1,676
I just used a flathead screw driver with a plastic bag folded 4 times over then put that over the screwdriver and just pry from a corner. But go slow. As soon as you can use your hands, use them. Try to pull somewhat evenly and slow
07 328xi Monaco Blue|Premium|Cold|Navi|CA|LLumar|Mtec|DDM|aFe|Ambe r-Gone|Rear Fogs|Bimmian|PY-Speed|OEM|e92-lighting|V1|BavAuto|Weisslicht|Cyba|Beyern|Falken| Sonic Tuning|ECS Tuning|JL Audio|Rockford Fosgate
09-13-2011, 06:45 PM | #4 |
boku no namae ha...
336
Rep 11,025
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
you can buy those plastic interior trim removers from harbor freight... pretty cheap with coupon
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
09-13-2011, 07:10 PM | #5 |
146
Rep 1,922
Drives: E90 335i, E70 X5
just a flat head and wrap around with electrical tape will be fine...
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
09-14-2011, 12:11 AM | #6 |
43
Rep 1,071
Thanks guys, I see nothing fancy. So just push in plastic wrap flat head and pull is all we need to remove the trim??
09-14-2011, 01:57 AM | #7 |
146
Rep 1,922
yes, for the doors trim, don't even needed... finger will do the work =)
-eric
09-14-2011, 11:44 AM | #9 |
New Lifetime Replacement Policy
818
Rep 11,738
The Trim Removal Tools make life a lot easier when pulling everything out of the car. I highly suggest out Schwaben tool kit for anyone that's planning on pulling all of the trim. It contains a few handy tools which fit around the pop clips and allow you to evenly apply pressure and remove the trim without causing damage. It might seem like over kill to some to have access to all these tools when a screw driver works for them, but I've scrapped and cracked too many trim pieces in the past using the screw driver method. I personally prefer tools designed to make life easier.
James |
09-14-2011, 12:04 PM | #10 |
81
Rep 6,092
flathead screwdrivers can work as most people use this method... BUT, once u try using actual trim removal tools, u cant go back. it may look like not much of a difference, but seriously its a HUGE difference in the whole process of removing pieces. your chances of breaking a clip is almost none, unlike a screwdriver where you have to be careful of not snapping clips and chipping the trim itself. this not only makes taking things off easier, it makes it super easy to put back on too.
