335i FBO + meth vs. M3 E46 Active Autowerke supercharged
09-12-2011, 04:00 PM | #1 |
36
Rep 332
Me against the most powerful M3 E46 in Greece.
M3 is supercharged with meth and 440 rwhp. Mine, FBO + Meth + 6-14 First pull, me standing on the wrong lane: second pull gets interesting until 250 km/h : Other cars: two M3s ESS supercharged, an unknown and modded Evo 9 and camera inside a tuned 996 turbo S. The M3 is very fast, especially at high speeds where it gets its max power over 7000 rpm. It has also SMG 2. I think now with rev. 3, leaner AFRs (stuck to 10.8 when hitting WOT) and after installing my 250 psi meth pump and M10 injector I could stand better. please comment |
09-12-2011, 04:24 PM | #2 |
3441
Rep 79,211
You can have those AFR adjusted. I dont know the specifics but you need to change the closed loop fuel settings. Better off contacting vishnu with a datalog.
Nice runs Last edited by Jeff@TopGearSolutions; 09-12-2011 at 04:50 PM.. |
09-12-2011, 04:27 PM | #3 |
161
Rep 7,377
he needs to go with the 7-29 maps ;-) better fueling with meth . Great runs!
09-12-2011, 04:47 PM | #4 |
734
Rep 4,635
coool, wish the camera was in one of the cars driving
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
09-12-2011, 05:01 PM | #6 |
23
Rep 1,142
7-11 feels much better than 7-29 maps. Well at least with my car. 7-29 just doesn't work right with my rev 2.5. Wastegates keep getting jammed
Great videos and runs! Last edited by cwn23; 09-12-2011 at 05:23 PM.. |
09-12-2011, 05:22 PM | #8 |
161
Rep 7,377
09-12-2011, 05:30 PM | #12 |
45
Rep 828
09-12-2011, 05:38 PM | #13 |
65
Rep 1,708
09-12-2011, 09:57 PM | #16 | |
Cobb Stage 2+/ICarbon/HPF/Stett
40
Rep 488
nice run |
09-13-2011, 09:16 AM | #17 | |
36
Rep 332
Me either. Rev. 3 could be leaner like rev. 2 (11.8) with 7-29 map. It must be the new hardware that calculates the mixture in a different way. I wish I could run low 12s, the car would be faster and that is not that risky for the engine.
Waiting an answer from Shiv... Thanks Gamise ta. pm me if you want Last edited by stratos_335; 09-13-2011 at 09:26 AM.. |
09-13-2011, 09:20 AM | #18 | ||
36
Rep 332
There are some settings regarding fueling and ignition control but it would be too risky adjusting them. Quote:
because we wanted the cars to be as light as possible, thus racing them without other passengers. |
09-13-2011, 09:45 AM | #19 |
161
Rep 7,377
did you try running the 7-29? load them and do some logs. I had very fat AFR as well with older maps and lots of meth.
09-13-2011, 01:09 PM | #20 | |
36
Rep 332
rev 2 18.5 psi run, AFR 11.8-11.9 and a lot boost tapper: rev 3 18.5 psi run, AFR 10.8 and less boost tapper: So, where is the difference? Same settings, same ambient temperature, rev. 3 not hitting 14 degrees of ignition advance but feels much faster due to less boost tapering and hitting boost in lower rpm. Really don't know how to explain. Any suggestions? |
09-13-2011, 01:15 PM | #21 |
161
Rep 7,377
