335i stock differential weight ?
09-12-2011, 03:05 PM | #1 |
151
Rep 1,809
Does anyone know how much does the 335i stock differential (including the diff case) weight ?
Thanks ! |
09-12-2011, 03:42 PM | #4 |
127
Rep 6,773
09-12-2011, 09:01 PM | #6 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Without fluid, mine was ~85 pounds.
The i8 needs a V8 amirite?
09-13-2011, 12:06 AM | #8 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Well I know the smaller pumpkin with the wavetrac was probably 10 pounds lighter than my stock large pumpkin. Not sure how much is attributed to the smaller design, but it doesn't seem like the diff unit itself could be much different.
09-13-2011, 12:42 AM | #9 |
30
Rep 1,041
When I received my Quaife diff (pumpkin) the box was 43 kg, i.e. about 95 pounds without fluid. We didn't weigh the standrd diff, but I don't think there's any significant weight difference. I carried both (in the box) and didn't notice any discernible difference
E92 335i 2008 Space Grey 6MT | Pure Stage 2 turbos | Motiv PI | Trueform Tech Intake | Quaife LSD | M3 Suspension kit | Öhlins Road & Track Coilover | DEFIVfab N54 diff lockdown kit | COBB PTF E85 Map | Fuel-It Stage 3 LPFP | NGK 5992 plugs | Wagner FMIC | Wagner 3" DP | Milltek exhaust | Tial BOV | SPEC Stage 3+ clutch | SPEC Steel SM Flywheel |
09-13-2011, 12:44 AM | #10 |
Some say...
239
Rep 4,296
Drives: Fresh
When mine had fluid it in with the wavetrac it was right at 100 pounds, that beesh was heavy, and a PITA lifting into place when the car is on jack stands.
I have exhaust and an intake... |
09-13-2011, 04:02 PM | #11 |
151
Rep 1,809
I just weighted mine with 2 scales. Without oil it only has 77 lbs. This is for the standard open differential. If the Quaife or Wavetrac add so much that it will weight 85lbs or 100lbs after fitting then I'm glad I chose the Drexler, they advertise lightweight as one of their strengths.
09-13-2011, 06:47 PM | #12 | |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
edit: actually you have a manual, which would be the larger pumpkin, so I'm surprised it only weighs that much.
09-14-2011, 11:24 AM | #16 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
3.08 fdr is for manual, all manuals are the larger pumpkin. And of course you can tell by the front being longer. Here is a comparison:
09-14-2011, 11:27 AM | #17 |
Some say...
239
Rep 4,296
Drives: Fresh
Yours is a dirty pumpkin, what do you do? Go mudriding?
09-14-2011, 12:15 PM | #18 |
151
Rep 1,809
10-16-2011, 12:32 PM | #19 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
