Torsen gear-type LSD(Quaife, Wavetrac) or clutch-type LSD (Drexler) for drag racing ?
09-12-2011, 08:20 AM | #1 |
151
Rep 1,809
Hi,
I am finally able to get myself a limited slip differential. I got some good offers from Quaife and Drexler, they are within like $500 of each other (Drelxer more expensive). The question is, biased opinions aside, which do you think is better for drag racing (and street) ? I keep reading that the clutch-type LSD is superior for the majority of situations, especially Drexler which is used in Mercedes AMG Black Series cars, BMW Motorsport cars, etc. On the other hand, I hear that gear-type LSDs are better "on the street" and are rarely used in racing. There are also differences on how do these behave in various conditions, like hard braking, corner exit, etc. I also hear that some of the clutch-type LSDs make some "noises" in operation. Does anyone have experience or opinions on using various types of LSDs in drag racing ? I would like to improve my traction on regular tires or poor quality launching surfaces. Cornering is not really my thing as of now, but who knows. So which should I choose ? PS: Yes, I know you love your Wavetrac |
09-12-2011, 08:53 AM | #3 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Agreed! Clutch type all the way. Drexler is expensive though. Look into OS Giken. Their clutch-type ones have significantly more clutch plates compared to drexler. If my memory serves me right, OS Giken has 21 plates and drexler has about 8. The point being is that OS Giken plates will last a lot longer.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
09-12-2011, 09:42 AM | #4 |
273
Rep 5,876
well for drag racing you'll be really heavy on your drivetrain (clutch/diff/axles)...i'd got with a gear-type LSD as there's much less chance of failure when compared to a clutch type diff just for the shear fact one's got clutches that wear (and much more so with constant launches) while gears in a diff won't...if you look at the gears there you'll see just how crazy big the gear teeth are on them
09-12-2011, 10:37 AM | #5 | |
151
Rep 1,809
Another problem of the gear-type diff is that it's heavier than the clutch type (significantly so). |
10-17-2011, 10:25 AM | #7 |
44
Rep 1,030
10-17-2011, 11:03 AM | #8 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Not familiar with the e90/n54 but you should also look into gearing while you're at it.
10-17-2011, 01:32 PM | #9 |
102
Rep 1,903
Drives: e92 335i 6MT
What kind of LSD does the M3 have?
10-17-2011, 01:33 PM | #10 |
AC
95
Rep 2,387
+1, if your torque is high enough (have seen in this forum), you could break the gears in a gear-based LSD.
for clutch-based LSD, you just wear the clutch-plates/pads.
Your Supreme Leader
10-17-2011, 01:39 PM | #11 |
38
Rep 565
I have used the Quaife LSD and currently am using the BMW M3 LSD and to me it seems the BMW is better when coming of the line (unless my driving has improved hehe). In the corners I feel they are pretty even.
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
10-17-2011, 01:42 PM | #12 | |
102
Rep 1,903
So is it a gear based LSD? |
10-17-2011, 03:20 PM | #14 |
38
Rep 565
It is possible and I have done it (search). Its clutch based, not sure what percentage though.
09 C63 |
10-17-2011, 03:55 PM | #15 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
+1, I have done it as well.
10-17-2011, 04:55 PM | #16 |
151
Rep 1,809
I chose the Drexler clutch-type and I now have so much traction off the line (Nitto 555R tires) that my clutch is slipping. I am very happy with it.
But to the those who retrofitted the M3 diff, did you use only OEM parts or did you have to adjust (cut) the driveshaft ? If using OEM parts only, how come there is no thread about this mod (except the one in which someone retrofitted it but had to cut the driveshaft) ? |
10-17-2011, 07:14 PM | #17 | |
38
Rep 565
09 C63 |
10-17-2011, 08:57 PM | #18 |
1121
Rep 5,396
Drexler makes the M3 diffs.
10-18-2011, 03:59 PM | #19 |
151
Rep 1,809
Some information:
- Dinan differential is a Torsen, so it's not clutch-type. It's written on their web site in the product description section. - Drexler does not make the M3 differentials, but BMW Motorsport differentials (for their race cars). - The M3 differential varies lock between 0-100% using clutches and a viscous pump activated by the difference between the speeds of the 2 rear wheels. The Drexler differential has 40% lock on acceleration and 60% lock on deceleration. Each of the two styles has advantages and disadvantages. |
10-19-2011, 05:34 AM | #20 |
94
Rep 1,184
10-19-2011, 06:00 AM | #21 | |
11
Rep 105
Would i need just the diff or the rear driveshafts/subframe etc? Sorry to be a pain but i need a lsd on my 335i so so bad!.............................................f unds are tied up for a new diff but i was just about to sell the diff tomorrow until i read this thread and if possible would put a big grin on my face. P.s......just realised................u were on about a e90/92 m3 diff and not e46 yes? |
10-19-2011, 07:19 AM | #22 |
38
Rep 565
The rear part of the driveshaft is M3, it matches the front part which is 35 part in my assumption with a universal joint. If you take the car to a qualified propshaft place they should have no issue. Shortening is required with a manual. The intersting part of this is covered with heat shields so cannot get a photo. I have a photo of the rear part which I will post in a few days as I am traveling abroad. The driveshafts of the M3 will work on the 335 but not 135 for some reason.
09 C63 |
