Keep getting "replace brake pads" red warning light??
09-12-2011, 05:03 AM | #1 |
Rep 44
Does anyone perhaps know what would keep causing the "replace brake pads" red warning light to go off on my 2007 335i 6AT?? Recently had both front and back discs + pads replaced by BMW, but have subsquently had to go back 4 times to get the warning light reset?? BMW say they have replaced both the sensors and done a CBS re-calabration (whatever that means?), but the light still keeps tripping after driving for 2-3 days? Whats interesting is thats both front & back warning lights come on at exactly the same time, so doubt it could be an individual sensor??
Very frustrating as I keep having to remove the Procede each time I take my car in, and I haven't been able to re-fit the DP's and IC yet. Is there a possibility that I may have damaged a wire or pin in the ECU box when re-installing the Procede that may be causing this? Ran a BT scan and no faults?? Or is the brake warning system controlled by a totally different module to the ECU?? Last edited by Baracus135i; 09-12-2011 at 05:12 AM.. |
09-12-2011, 08:30 AM | #2 |
112
Rep 4,771
Resetting the brake pads in the BMW software can cause an error light of the system thinks that the pads are more worn than what you are suggesting. This can have to do with the sensors.
I remember there was a brake pad diy that covered this. You might want to search for that and see if there is anything that BMW might have overlooked |
09-12-2011, 10:12 AM | #3 |
36
Rep 1,054
does your version of procede remove the limiter on a non sport car? ie. you have a car with a limiter set at 135, not 155 and you are exceeding the 135 limit? This will happen to me sometimes and I think its the Active Autowerks SLD tricking the ecu and not wheel sensors. I am not sure, but I use BT to clear the codes myself for speed plausability and sometimes the brake sensors.
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
09-12-2011, 03:06 PM | #5 | |
Rep 44
I've got a BT cable but couldn't find any codes to reset though? Or is there a separate procedure to reset the sensors using the BT software? |
09-12-2011, 03:11 PM | #6 | |
Rep 44
09-12-2011, 03:18 PM | #7 | |
133
Rep 4,764
Screen print here: http://www.bavariantechnic.com/Condi...edService.aspx More detail on their wiki: http://wiki.bavariantechnic.com/index.php?title=CBS Will be interesting to see what your CBS is for brake pads. If it's not extended out then they lied about reseting it for you. If it is out in the future than something may be wrong with your brake wear sensors. Last edited by scottp999; 09-12-2011 at 03:26 PM.. |
09-12-2011, 04:04 PM | #9 |
130
Rep 2,291
You shouldn't have to do all of that. Search youtube for a video showing you how to reset the brake service light. Its been over a year since I did it, but you have to do a combination of inserting your key and pressing a couple of buttons. Then the light will go away (providing that you installed a working sensor correctly).
09-12-2011, 04:08 PM | #10 | |
Rep 44
Does this mean BMW didn't reset properly or alternatively is there something wrong with the wear sensors? |
09-12-2011, 04:32 PM | #11 | |
Rep 44
09-12-2011, 04:48 PM | #12 | |
161
Rep 7,377
was driving me mad as well.
09-12-2011, 07:08 PM | #13 |
133
Rep 4,764
When you hit adjust value what does it say? Can you post a screen print of that? A service count of 14 and 16 seems very high, so they have definitely been trying to set it.
09-13-2011, 04:00 AM | #14 |
38
Rep 565
If its bad sensors is bridging them a option to see if it goes away?
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
09-13-2011, 04:06 AM | #15 | |
161
Rep 7,377
seems they have no clue...
09-13-2011, 04:20 AM | #16 |
Rep 44
Cool thanks, will put some pressure on them now and ask for proof that the sensors have indeed been changed? Yep some of these local South African BMW agents really have no freakin clue, not the first time these guys cant fix silly issues
09-13-2011, 09:18 AM | #17 |
133
Rep 4,764
Still would like to see you post a picture of what the screen looks like if you hit the adjust values button. It is interesting that all other CBS items have a percentage next to them and the brake pads do not. Thanks.
09-13-2011, 12:35 PM | #19 |
Rep 44
09-13-2011, 02:59 PM | #20 |
103
Rep 1,520
09-13-2011, 06:19 PM | #21 |
47
Rep 731
freaking weird, but I just had my car in for a oil change and a service inspection.
After i got the car back I have the same exact issue with the e-brake dash light "brake" and when I turn off the car it has the car on the lift symbol for service. When i scroll through the service info stuff both my front and rear brakes have ------ listed as miles left on them. Im going back to the shop tomorrow to have him reflash it and try to reset them. |
09-14-2011, 06:39 AM | #22 |
8
Rep 436
Cannot say for sure if it was after reversing.
