What are Characteristics of a good timing curve?
09-10-2011, 09:36 AM | #1 |
18
Rep 462
Lots of discussion lately about timing advance.
What should we be looking for ideally in a timing curve? -Flat slope under boost? - Increasing slope? - No dips of negative slope? - average around 10deg BTDC? -? Lots of threads with comments on timing curves as "good" or "bad", but hard to find some with some pointed specifics about exactly what the curve should look like under boost. Comments appreicated. BTW, question (for me) is relevant to this thread http://www.e90post.com/forums/showthread.php?t=581083 |
09-10-2011, 09:38 AM | #2 |
915
Rep 3,456
Drives: Harrop E90 M3
I'll be watching this...:-)
09-10-2011, 09:47 AM | #3 |
161
Rep 7,377
this one is pretty good
09-10-2011, 10:14 AM | #4 |
3441
Rep 79,211
Depends if your using methanol or not.
With methanol 10+ across the board is ideal. Without depending on the tune and other exterior factors it can gas low as 2 degrees in the mid-range ramping up to 10 or so by redline. They key is minimal timing drop outs (ideally none). IE 7 degrees ignition dropping to 2. It needs to look smooth. As tunes become more advance you will likely see different timing curves with more advance on the top end. Last edited by Jeff@TopGearSolutions; 09-10-2011 at 10:28 AM.. |
09-10-2011, 10:41 AM | #5 | |
18
Rep 462
What do you think of this log running Meth? 4th gear appears to look really good (flat right at 10deg), but not sure why 2nd and 3rd are low to start out. I think its good that 2nd and 3rd only increase up to 10deg, but not 100% sure if I should be looking for something. These runs are only 15psi (V5 50% boost setting), but I believe this boost to be roughly equivelent to between 17.5 and 18psi at sea level. IF these should look more smooth, then I'm just wondering if I should be backing off bosst just slightly to 14.5 psi or not Other relevant factors: pull was done at ~60F ambient temps on 91oct + PWM METH (75/25) 50%UT 0%IC Here is the log in question: |
09-10-2011, 10:50 AM | #6 |
161
Rep 7,377
try to display the log as i do. is difficult to see well from yours. log only before you go wot.
09-10-2011, 11:00 AM | #7 |
18
Rep 462
I'll try again, but whenever I tried to zoom in further than this the vishnu SW it cut off some of the end of this log. Unless you are saying take another log and don't start it until just before the pull??
09-10-2011, 12:39 PM | #8 |
36
Rep 332
09-10-2011, 02:22 PM | #9 |
161
Rep 7,377
[QUOTE=enrita;10393979]try to display the log as i do. is difficult to see well from yours. log only before you go wot.[/QUOTE]
09-10-2011, 02:38 PM | #10 |
161
Rep 7,377
this is on rev2 upped turbos and tons of meth
09-10-2011, 07:09 PM | #11 |
36
Rep 332
09-10-2011, 10:05 PM | #12 |
184
Rep 2,841
Enrita.....perfect logs!
Is 12.7 AF ratio kind of lean? I run procede and it sits around 11.8 to 12.1 on my logs......but feels a bit rich now that I am on meth. I was thinking of leaning out the open loop fueling a bit, but wasn't sure how lean you could go. 12.5ish? |
09-10-2011, 11:13 PM | #14 | |
273
Rep 5,876
09-10-2011, 11:25 PM | #15 |
102
Rep 3,460
A perfect timing curve is when you hit your timing targets. If you don't know what those timing targets are, look for gradually increasing smooth timing graphs. Also dont be fooled by 1 gear wonders, make sure you can hit the same timing at the same rpm in multiple gear pulls. If you can't you are relying on the ecu to react to knock.
09-11-2011, 12:32 AM | #16 | |
112
Rep 4,771
09-11-2011, 01:34 AM | #17 |
3441
Rep 79,211
