Cobb break-in period
09-09-2011, 02:02 PM | #1 |
Rep 33
Just installed the AP yesterday. I was only able to test it out a few times. It felt like a noticeable increase from stock, but I was curious on the "break-in" for the tune.
Does the ECU/tune have a short learning period? What is the range (ballpark) around? the first 100 miles or so? Next, if I'm thinking of switching to the valet map for my daily commute, would that reset the "learning period" that was building up in the ECU/tune prior to switching away from the 91 map? In other words, for a daily basis, would it be advisable to be in valet mode during commute/heavy traffic, and switch maps for spirited driving afterwards? Don't want to waste all the "learned" data. Any long term pros/cons from using valet on a consistent basis? Thought it would be a good chance to get some more mpg out of the car. Thanks guys! |
09-09-2011, 02:06 PM | #2 |
3441
Rep 79,211
There is no learning. It is a flash tune so it just runs the tables within. Drive it like you stole it. I wouldnt bother changing maps.
09-09-2011, 02:44 PM | #4 |
130
Rep 5,040
there is a bit of learning - since the reflash clears all adaptations, the ECU needs to relearn those. I find the tune gets a bit more power and smoothness after a day or two....
I would advise against flashing to valet mode during your commute - just pick a map and keep it there |
09-09-2011, 04:38 PM | #5 |
161
Rep 7,377
changing maps is a myth , once you try it you will never go back.
09-09-2011, 04:44 PM | #6 |
469
Rep 4,392
Its a flash and since it does not manipulate the DME like a piggy does, it takes about 100 miles for the DME to adapt to the new founded power and the driver's syle of driving.
After 100 miles take your car through car wash |
09-10-2011, 03:22 AM | #7 |
Rep 33
Thanks for the responses/opinions guys.
Anyone from/with Cobb that can comment? BuraQ, im not sure what your comment about the car wash means? im probably out of the loop on the terminology if you meant something else. -_- |
09-10-2011, 04:36 AM | #8 |
164
Rep 2,875
I think that's a myth.....Unless you've done a dyno right after the flash and another one a few days later and show proven gains.....
IMO, it manipulates the DME just like a piggy does, just in a different way.....
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
09-10-2011, 07:50 AM | #10 |
32
Rep 878
after a few WOT runs the car should feel more smoother, i just keep it on the same map for DD, i suggest not going into valet mode cause if you want to pass someone you will not be able to because i think valet cuts power at 3k rpm. you can go to stock map but the mpg isnt that bad with stg1.
08 335i | Space Gray | Burl Walnut Wood Trim | Sport pkg | Premium Pkg | LOGIC7 | Navi | Comfort Access
| COBB | Injen DCI | Active Autowerke | Sonic Tuning | E92 Lighting | ER | HKS | BMS | Ground Control | Vortex Tuning | |
09-10-2011, 09:18 AM | #12 |
20
Rep 659
uhh i would definitely NOT run valet mode haha. that's for driving around a parking lot at 10 mph, not for daily driving. switch it to map 0 if you must. but i doubt even doing that will result in a meaningful increase in mpg. i was averaging 21 mpg (xi) untuned and with stage 1 i'm averaging 20 mpg. the 1 mpg difference is probably due to the fact that i like to boost it more now that there is the extra power. map switching is for the birds
09-12-2011, 10:55 AM | #13 |
233
Rep 1,051
The ECU can learn and adapt to things like gas or atmospheric conditions. I'd recommend installing the AP and then driving the car how you normally would! That way, it will learn from your driving habits and conditions right from the start.
Ian |
09-12-2011, 12:05 PM | #14 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
09-12-2011, 12:09 PM | #15 |
475
Rep 13,583
Drives: JB E92 335i
^ +1 Couldn't have said it better myself.
09-14-2011, 10:30 PM | #16 |
164
Rep 2,875
Let me put it this way. Anything that deviates from the factory form is manipulation, one way or another, no matter how you slice it.......Just my opinion though.
