Helpppp Please!! Rear Rotors Question!!!
09-09-2011, 09:10 AM | #1 |
10
Rep 36
so im replacing my rear brake pads and rotors but i have no idea how to remove my rotors. so if you can point me in the right direction that would be greatly appreciated!
p.s. I've been searching the web all over for diy guides but can't find any!! |
09-09-2011, 10:18 AM | #3 |
all about that N54 life
42
Rep 206
The rotors are held on by an allen screw. You'll have to unscrew it. you'll also need a rubber mallet to hit the rotor off cause it'll still be stuck on the hub. Hope this helps. Gl.
09-09-2011, 10:21 AM | #4 |
1821
Rep 5,337
Release the hand brake.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
09-09-2011, 02:47 PM | #7 |
Been there, wrecked that.
18
Rep 547
After 100K miles, even a small sledge was of no help. I ended up using the hyd jack to (slowly/slightly) push up on the rotor. The leverage broke the corrosion bond.
OP, if you don't understand the connection between an engaged hand brake lever and the effect of the brake shoes on the hub of the rear rotor, it might be time to use your life line to call a (mech-savvy) friend.
-Brian
~199K miles. I -still- don't fear my 335i. |
09-09-2011, 03:06 PM | #8 |
10
Rep 36
Gotttttt dayummmm!!!! Finally got it!!! Haf buy PB blaster and sprayed it around the hub area, let ir soak for a little then spray some more, then knock it from behind (pushing the rotors towards you. Then voila!!! It's out!!!!!!
09-12-2011, 11:04 AM | #10 |
1821
Rep 5,337
Because it's a common mistake. Heck I've done it multiple times. Wail on the rotor for 20 minutes only to realize that the hand-brake is on.
I've never heard this one before.
