Afe sealed elite stage 2 intake?
09-08-2011, 05:51 PM | #1 |
172
Rep 1,909
Read lots of threads about this, but most are vendors trying to pitch the product or people commenting without any experiance with this intake. These threads end up going nowhere with no evidence/dynos. Who has/had this intake, and what do you have to say about it? I've got a DCI w/ scoops and factory snorkel bent over towards the filters right now, but am thinking about this. It looks like this:
[IMG]http://www.**********s.com/images/Products/AFE%20Intake/50-81472_installed.jpg[/IMG]
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) Last edited by Stucks; 09-08-2011 at 05:59 PM.. |
09-08-2011, 06:00 PM | #2 |
35
Rep 450
i am interested in this aswell. of all the ones i've looked at it looks to be the most functional but i would like to see real world results both with and without other bolt-ons
09-08-2011, 06:23 PM | #3 |
469
Rep 4,392
I have been considering this CAI system for my 355is since Dinan has not come out with a new CAI for the 335is
However I do not think this CAI is the actual key for higher performance gain. I think the Air Scoops and the cone filter are the actual key here. The airbox may hold more volume of air than the factory box. However though I think since the airbox is so big the CFM air suction will be greater at the filter than at the air scoops. My idea is to keep the factory CAI, but swap out the factory filter for a K&N direct replacement filter and add the aFe air scoops. Being that the factory box is not oversized the CFM suction at the box will be closer to the same CFM at the air scoops having a "stronger" pull on outside air at lower speeds. At higher speeds the air CFMs, with the air scoops, will literally be forcing down the factory CAI in which I see of having less air traps as oposed to the bigger aFe airbox. |
09-08-2011, 07:45 PM | #5 |
153
Rep 3,730
And too restrictive! I want to see some 3rd party dyno's.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-08-2011, 07:56 PM | #6 |
22
Rep 575
09-08-2011, 07:58 PM | #7 | |
22
Rep 575
09-09-2011, 03:11 AM | #9 |
127
Rep 6,773
Had a vendor on here who told me they tested it..and it flows the same rate as no filter at all..hes a vendor I have worked with for yrs so Im not doubting him...it would be great to get some independent data tho..n it is way overpriced IMO
09-09-2011, 03:24 AM | #10 | |
79
Rep 1,617
To me the AFE sealed intake looks like the best solution currently out there. Would be great to get some independant dynos.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
09-09-2011, 10:48 AM | #11 |
Rep 300
Yes... this intake is extraordinarily expensive, but would appear to be a good option for folks who have 335is, PPK, Vishnu PWM kit, or other obstruction where a Mr5 style induction hose would go.
FYI, I shopped around a bit, and it would appear that Amazon has one left at $703.00, which is a few bucks less than the closest competitor. (I happen to be in CA where that competitor is, so I save tax, and shipping because I have Amazon Prime.) Anyway, I *think* we can make a nice alternative product out of Fiberglass or CF, like the one that was done for the B5 S4, so I've ordered this AFE 335 one for R&D. It so happens that I have an otherwise stock car, and a nearby dyno, so I can produce some data if anyone is particularly interested. I should have the AFE unit to test on Tuesday.
DD: 2007 BMW 335i Sedan
Weekends: 2004 Porsche 911 C4S Last edited by Skydive; 09-09-2011 at 11:05 AM.. |
09-09-2011, 11:07 AM | #12 |
8
Rep 70
Ive been looking at these as well. When searching their site they list 2 versions of the Stage 2 Si.
$520 - Direct from aFe $940 - Direct from aFe The sealed box looks to be identical (they even claim identical hp/tq increase), its basically $420 for the intake ducts and air scoops. Looks like a really well made product, it takes a lot of work and investment to have stuff molded out of plastic.
09-09-2011, 12:30 PM | #13 |
153
Rep 3,730
^ Other than a cone filter, it appears to be no less restrictive than the stock box. It's just dividing the one snorkle into 2 seperate (smaller) snorkles.
09-09-2011, 04:55 PM | #14 | |
469
Rep 4,392
The stock box gives more air room in the box between the filter and the lid. So for me I think I would settle for the air scoop and a K&N filter inorder to retain the stock box. What I would like to see is LARGER snorkle air ducts for the stock box |
09-10-2011, 12:59 PM | #15 |
207
Rep 422
I did have aFE Stage II box (version 920usd) in the past and had bad experiences, so i change my setup to a custom made DCI after a few weeks, which now has far-far better result (in gains of air flow). Quality was not as expected, there were some fitment issues as well...
The cheaper one, which is a latest production is a big question. I can imagine, that aFE realized his poor product in gains of flow and fitment and maybe recalibrated the product. |
09-10-2011, 05:37 PM | #16 |
102
Rep 1,903
Drives: e92 335i 6MT
+1. Otherwise, you are better off getting a Stett CAI for ~$380 shipped. I have one and am very pleased with it.
09-10-2011, 06:12 PM | #17 |
24
Rep 1,244
