BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > USB/AUX socket -> usb cable -> MULF2
      09-08-2011, 05:03 PM   #1
minimega
Drives: 320d e91
Hi to all,
after coded MULF2 and Radio Professional in my e91 I bought on Ebay the USB/AUX socket for USB pen drive.
What I expecting was that socket cable goes directly connected to the MULF connector, but the white USB connector is male and the same male connector in on the MULF2 side. So I think there must be another long cable with female connectors on both side, to connect USB/AUX socket to MULF2 (I think this socket goes inside the armrest, isn't so?)
USB/AUX socket has BMW code 61319129651 and I need to know the code of the female-femal cable or where to find/buy those female connectors to build the cable by myself.
On the white USB connectors cover, the male BMW code is 6982237, the female one is 6982242.
Thanks a lot!
      03-07-2012, 08:11 PM   #2
roadmax
Drives: M3 Coupe
Re
Have you found any info on this. What type of connector is the white 4 pin round one, is there a name for this type of connector. It is similar to mini din but I think it is smaller looking at the picture.
      03-07-2012, 08:22 PM   #3
GenePoole
46
Drives: 2012 F30 328i
I wired mine to a Dension 500, but I just stripped the end of a USB extension cable and soldered the wires in the cable to the pins. It was tough getting my soldering iron in that tight space, but I managed it.
FWIW, I think it's a some style of FAKRA connection, but I've only seen FAKRA use SMA coaxial connectors (where the circular part is):
http://www.pasternack.com/fakra-cabl...-category.aspx
      03-07-2012, 08:31 PM   #4
GTiceman
Parrothead
GTiceman's Avatar
137
Drives: E90 M3
2020 BMW X3 M40i   [0.00]
2009 BMW M3  [0.00]
it is a fakra connector, i attempted this retrofit as well but stopped when I realized that I needed a full retrofit harness that ran to the usb hub that goes in the drivers footwell from the mulf2 and from the hub to the center console
|e46 M3 Stahlgrau/Red| - Sold
|E92 335i BSM/Saddle| - Sold
|e90 M3 Space Gray/Fox Red/6MT|
See Garage for Mods
      03-07-2012, 11:00 PM   #5
roadmax
Drives: M3 Coupe
Re
Thanks to both for replies. Now I'm alomost undecided should I go with this connector or just solder which is less expensive.
GenePoole, did you solder only 4 wires to 4 pins or also one wire (5th wire) to the round metal casing on the rear? I need to know if the round metal serves for any contact.
      03-08-2012, 07:22 AM   #6
GenePoole
46
That is the shield. It is same as ground, but it should be connected if possible to shield from spurious emissions from other electrical stuff in the car. I just kept the foil shield under the cable covering relatively intact, and when I was done, wrapped it around the metal and secured it all with heat-shrink tubing. I had to cut the plastic part off with a dremel to accomplish all this.
      05-10-2012, 12:04 AM   #7
roadmax
Drives: M3 Coupe
BMW USB Aux-In
First thanks for your info...this was time consuming but wanted to have it better than BMW (illuminated), lol.
Pictures of before and after instal is completed.
      09-16-2012, 07:28 PM   #8
roadmax
Drives: M3 Coupe
Re
Center console USB/Aux-In and glovebox USB sockets.
      09-16-2012, 07:30 PM   #9
roadmax
Drives: M3 Coupe
Re
