Windshield Washer tank and Meth... Question.
09-08-2011, 02:24 PM | #1 |
I sweat pheromones
203
Rep 2,103
I've looked, but haven't found the answer.
When using the WW tank, I've read the capacity is 1.5 gallons. However, unless it's empty, there's no way to tell how much you need to fill. What happens if you overfill the tank? Is there a drain somewhere? If so, where? Is it anywhere near the engine? Normally, I would never add meth to a hot car. But for those of us who track their cars, it is a necessity and I would like to do so the safest way possible. BTW, I cut a piece of cardboard that fits around the WW cap. When I fill the tank, it absorbs any splash that would otherwise hit the engine or worse yet, the turbo. |
09-08-2011, 02:28 PM | #2 |
3441
Rep 79,211
I'm not sure what your asking. If you overfill it spills in the engine bay?
When you pour the meth in watch for it to fill in the neck and stop. |
09-08-2011, 02:28 PM | #3 |
153
Rep 3,730
Dan,
There is no drain on the WW tank. If you overfill, worst case scenario it will overflow out the top. My best advise is pour slowing and ALWAYS make sure you tie/tap down the cap so it doesn't pop open when driving (that's my largest fear). I've spilled some on the turbos in the past....with 50/50 mix nothing happened. Add some food coloring so you can see how far up the WW tank neck the mixture is.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-08-2011, 03:09 PM | #4 |
Formerly (-(ellblazer420
48
Rep 703
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
The WW tank does have a vent. I have filled meth all the way up to the cap many times and never seen meth actually come out of this vent. When I was cleaning the WW tank filter I noticed it. If meth were to theoretically flow out this vent it would drain into the fender area away from the engine. But again I've never seen any meth come out of this vent. Or maybe it is coming out the vent and I cannot see it. Either way I've never really worried about it and I sometimes run 100% meth. Hope that helps?
09-08-2011, 03:35 PM | #5 |
65
Rep 1,708
Even if you see fluid in the filler hose the tank is NOT necessarily full, due to the height of each.
http://www.realoem.com/bmw/diagrams/z/d/305.png http://www.realoem.com/bmw/diagrams/z/i/247.png Man, I still don't know how to add pics without attaching them. |
09-08-2011, 11:48 PM | #6 | |
79
Rep 586
2021 Mercedes G550
2015 X5M 2020 Supra-JB4, DP 2008 M5 with muffler delete-sold 2007 650i-sold 2008 335i-JB4, DP, Meth-sold |
09-09-2011, 11:44 AM | #7 |
I sweat pheromones
203
Rep 2,103
Thank you fellas for the responses. I'm going to test it out now. We'll see what happens when I fill her up. And although I agree that I should pour in slow, I'm just thinking about worst case scenario.
I used a 5 gallon fuel jug. I can pour slow but what if the flex tube pulls out? What if I miscalculate and overfill? Blah Blah Blah. You get my point. I hope hellblazer and 335i101 are right. If it drains into the wheel well. That would be ideal. |
09-09-2011, 12:09 PM | #8 |
I sweat pheromones
203
Rep 2,103
Okay, so here's my setup. I cut a spray bottle that fit PERFECTLY into the reservoir line.
Next, I cut 2 pieces of cardboard that fits around the narrowest section of the bottle. This absorbs any spray/accidental spill. Next, I fill up until I hear splashing. You can see the fluid line right below the black portion of the reservoir cap. Meth never had overflow here. What was the splashing? Meth pouring out just under the front of the rocker panel. Now we know and knowing is half the battle. |
09-09-2011, 12:11 PM | #9 |
153
Rep 3,730
I just use a large funnel, no need for the cardboard either.
09-09-2011, 12:15 PM | #10 |
I sweat pheromones
203
Rep 2,103
I have a large funnel too but the its fat and wide and doesn't fit tight like this upside-down bottle. I have a long neck funnel too but then it sits so high I can't see inside. The only reason I'm using the cardboard is for safety. This will be at the track between sessions. Rather be safe than on fire. lol.
09-09-2011, 12:22 PM | #11 | |
153
Rep 3,730
On anothe note, someone needs to come up with a locking WW cap. It is far too easy to pop off and in the event of a high G turn, fluid could easily push the cap off and spill over. I saw a very long time ago Terry had such a cap on one of his cars, not sure if he ever produced more.
09-09-2011, 01:06 PM | #12 | |
3441
Rep 79,211
Mine sure as hell doesnt leak. You might want to take it out and inspect. |
09-09-2011, 01:23 PM | #13 |
48
Rep 703
WAYYYYYY to much effort put into filling the tank with meth. I bought this 1.25 gallon water dispenser. I mix the meth and distilled water in this bottle. It has a little faucet at the bottom. You just place the faucet over the fill point on the WW tank and open the faucet. Takes only a few seconds and 0 spilling. I highly recommend this setup. It works flawlessly and is super easy. Plus you will never overfill because it only is 1.25 gallons.
09-09-2011, 02:10 PM | #14 | |
I sweat pheromones
203
Rep 2,103
09-09-2011, 02:14 PM | #16 |
48
Rep 703
Yea I still buy my meth in 5 gallon jugs and keep the distilled water in a 5 gallon jug. When I see the unhappy low washer fluid signal on the dash I just mix up some meth real quick in the back yard and I'm good to go. It was Rob and Shiv who gave me the idea to use the water dispenser.
09-09-2011, 02:16 PM | #17 | |
3441
Rep 79,211
Mine did not leak anywhere else. |
09-09-2011, 02:16 PM | #18 |
48
Rep 703
Yea good call. I usually leave it outside next to my meth jug and water jug. I tell my fiance to not even go within 5 feet of it or she will go blind. HAHA after that she won't go near the stuff.
09-09-2011, 02:18 PM | #19 | |
57
Rep 1,054
I found this: http://www.flickr.com/photos/fastxtc...in/photostream ...a picture of our windshield pump (Part number 67126934159) with a leaking output... Thats definitely something you don't wanna happen if you're gonna pump meth through it. I'm glad having my explosive liquid in a safe container in the trunk... |
09-09-2011, 02:19 PM | #20 | |
3441
Rep 79,211
09-09-2011, 02:25 PM | #21 |
28
Rep 300
Tags |
pwm |
