Helix vs. HPF intercooler
09-07-2011, 11:43 PM | #1 |
Rep 47
As the title says, I want to know which intercooler is better in terms of installation and removal, efficiency and overall quality. I have heard great things about the Helix intercooler but i know the HPF utilizes the factory quick connects which would probably make the removal and replacement of it easier.
However, I also know that the HPF requires cutting during the install but I wouldn't mind a little cutting if the HPF is really a more efficient design. I would really appreciate some advice because I want to go stage 2 when the cobb tune is released. Thanks in advance. |
09-08-2011, 06:22 AM | #3 |
24
Rep 1,244
Typically, comparing the top brand FMIC's is like asking GT2 or Ferrari. You won't go wrong with either. I have an ER and love it but would've bought the Helix if it was in stock as I needed one immediately.
09-08-2011, 06:26 AM | #4 |
151
Rep 1,809
I would choose the Helix. It has more frontal area which is the most important thing. The latest versions do not require cutting which is also important. There are many reviews and logs from which you can see it is very efficient.
09-08-2011, 07:43 AM | #5 |
866
Rep 5,450
One nice thing about the HPF for installation is that you can get it with stock charge pipe connectors, so it wins on the ease of installation. A lot of people argue you need bigger piping, but it seems from any data I have seen that the stock piping is fine with the stock turbos even up to 15-16 psi. In terms of build quality they seem pretty similar, both nice quality units.
Not sure how much the extra frontal area helps as it doesn't get direct airflow - AA did the same thing, but provided a shroud to direct air into the portion that is behind the bumper. I think you can't go wrong with either though!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
09-08-2011, 08:56 AM | #6 | |
80
Rep 1,283
09-08-2011, 10:24 AM | #7 |
153
Rep 3,730
Which ever you get the best deal on
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-08-2011, 10:44 AM | #8 |
New Lifetime Replacement Policy
816
Rep 11,738
If I may suggest a 3rd alternative, we carry the Forge Front Mount Intercooler. With it the average inlet temperature was 15 degrees Celsius colder than that of a stock intercooler. This is larger than stock size and is an easy bolt on without any modification upgrade. The complete kit includes new silicone hoses and clamps with complete instructions.
James |
09-08-2011, 11:38 AM | #11 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Waiting on my HPF unit to be shipped today...
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
09-08-2011, 11:55 AM | #13 |
112
Rep 4,771
09-08-2011, 12:22 PM | #15 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
everyone's going to chime in on what they use, so I will follow suit.
I am very happy with my helix. Here is some hotter temp log I ran with my helix. Even after 4 zero to 110+mph runs in 3mins, the intake temp was only 70 degrees over ambient. As I have a DCI, its sucking hot air as is, so the fmic, really works to cool temps. This was some extreme abuse compared to my normal driving habits, so generally, i never see intake temps more than 10-20 over ambient. http://www.e90post.com/forums/showpo...09&postcount=5 If you are going to track your car and have sustained runs, then I dont think any FMIC will prevent you from heat soat. Only a meth kit will really protect you. |
09-08-2011, 12:22 PM | #16 |
150
Rep 2,221
Our install is fairly easy, no trimming and we have a youtube install video if youd like to check it out:
Our intercooler has been chosen for the Burger and Vishnu shop cars in both the N54 and n55 platform. Shiv has said on countless occasions that he has tested the top intercoolers and ours came out on top. If you would like more information please PM me and I can answer any questions you may have. |
09-08-2011, 12:26 PM | #17 |
734
Rep 4,635
heard nothing but great things about helix, but to be honest a intercooler is an intercooler. I have a cxracing intercooler and its great in this 100 degree weather in cali. Or the big tom one is a nice set up. If the helix replaces piping with larger pipes and hpf doesnt than go with helix for more flow
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
09-08-2011, 12:26 PM | #18 |
24
Rep 592
Drives: JB 335i-M3
What about CP-e is it a good cooler? does the oil cooler help at all?
09-08-2011, 01:19 PM | #21 |
80
Rep 1,283
Guys notice the area above the mounting brackets on each intercooler is the exposed ambient face, look at the size difference
For some reason some manufacturers chose to enlarge the core below the lower plastic cowl that is not exposed to oncoming air heres a closeup pic of where the core ends just at the bumper fully exposed above the plastic cowl: Here's a pic of my old 335 showing that the entire helix core above this cowl is exposed to the ambient air source Last edited by TurboBullett@Ambient Thermal Management; 09-10-2011 at 09:10 AM.. |
