need help from the tuning guru's
09-07-2011, 10:37 PM | #1 |
Rep 82
here's my dilemma, i want RB turbo's but i got a dinan stage 2 tune. first can i even run those turbo's with that tune? i know it'd be a waste probably since they'll only be at 13-14 psi. Second how hard is it to switch out an ecu on these cars? what i mean by this does it have EWS II or something of that sort. I know on my e36 i've switched out the ecu plenty of times and all i would have to do is align the ews and car would start. I'd like to get a different tune with the rb turbos but dont want a 2000 dinan tune to go to waste so would try to swap ecu's with someone. any help would be appreciated
09-07-2011, 10:39 PM | #2 |
177
Rep 6,631
I guess you could buy a second DME and get it reprogrammed. But honestly, it won't be a waste getting the car flashed back to stock. Virtually any of the major tune offerings drives better than the Dinan
I can speak because I've driven a car with the Dinan stage 2 tune. Definitely peppier than stock, but any of the major tunes (Procede, Jb4, Cobb) run circles around it.
E90 LCI N54 6AT
09-07-2011, 11:23 PM | #5 |
153
Rep 3,730
Step 1 - Get FBO + Meth first
Step 2 - Reflash DME and erase the Dinan Step 3 - Buy a Piggy or wait for Cobb Stage 2 or ATR If interested, you better get in line for the RB waiting list. ** You can still use the Dinan with the RB's, just won't be boosting over 14 psi. However, that 14 psi will pull stronger than any stock turbo could.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-08-2011, 04:00 AM | #6 | |
278
Rep 5,062
Drives: Black e92 335i
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
09-08-2011, 10:13 PM | #8 |
Rep 82
09-09-2011, 08:38 AM | #10 |
76
Rep 911
Full Bolt Ons
DP, DCI, IC, exhaust.... correct me if i'm wrong
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
09-09-2011, 09:31 AM | #11 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
right, + meth
09-09-2011, 09:41 AM | #13 | |
65
Rep 1,708
Dzenno, you ran std Cobb stg 1 with RBs right? any issues with WG control, throttle closing? |
09-09-2011, 10:36 AM | #14 |
164
Rep 2,875
Plus there's a 30 day money back for the piggies( procede and JB)....so you really have nothing to lose IMO.
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
09-09-2011, 10:38 AM | #15 | |
3441
Rep 79,211
09-09-2011, 11:04 AM | #16 | |
Joint Chiefs of Staff
4918
Rep 115,980
As for getting new turbos you will definitely want something that can boost into the 17+ PSI range and there is no point getting the turbos if you aren't going to raise the boost. Especially with Dinan as they taper boost in the high RPM like crazy and thats where the RB tubes shine. As mentioned here meth is also a great addition. It really sounds like you need to eventually ditch the Dinan and go with a more powerful tune. Mike |
