bms jb3 CAN tool for sale
09-07-2011, 12:49 PM | #1 |
Rep 11
bms jb3 CAN tool for sale if interested please email me at vkraff@gmail.com
$50 plus $10 for ship • Read ECU codes • Delete ECU codes • Auto-delete annoying tuner detection codes • Auto-delete annoying exhaust modification codes (non-emissions use only) eliminating the need for a DPFIX! • User adjustable in dash gauge display including boost, timing, and air intake temperature • User adjustable shift light • No laptop required! • Not locked to a specific VIN -- use on as many cars as you'd like • DB9 port allowing firmware updates with the BMS USB cable • Free firmware updates! Many more features to come! Applications: • 2008 + N54/N55/Diesel Turbo Models • 2007 support and ECU mounting harness* coming soon! *ECU mounting harness required to display actual boost pressure with a piggyback tuning system (such as the JB3) as the OBDII port is not aware of the true boost pressure. In OBDII mode in dash boost will only be accurate on stock and ECU reflashed vehicles. $50 plus $10 for ship |
09-07-2011, 01:55 PM | #2 |
161
Rep 7,377
wrong section...
