which M3 bits?
09-07-2011, 09:40 AM | #1 |
70
Rep 441
which M3 bits?
I'm probably going with the BMW performance suspension, and pretty soon. In the 'might as well, since things are apart under there anyway...' category, what additional bits from the M3 suspension should I consider?
Thanks.
2009 E90 328i Montego Blue, Black Leather, 6MT, ZPP, Logic 7, HD radio, CA, fold-down seats, PDC. ED pickup 6/12/2009 mods: Koni FSDs, Eibach Pro's, Sport/Heated Seats, BMW Perf. short shifter, M-tech shift knob/e-brake handle/steering wheel, split armrest, black grilles, 50% tint, 3M clear bra. |
09-07-2011, 11:10 AM | #2 | |
25
Rep 423
Drives: 2007 328i, 1998 328i
Are you happy with the car as it is now? I hesitate to say this, but I recommend caution upgrading to BMW performance. This is only based on my own experience; others do like it. For me it was a $1000+ mistake. I think it's better to look at upgrading shocks only. But, it depends what you want.
2007 328i ZSP. M3 suspension: custom valved Bilstein shocks, Hyperco race springs, M3 lower control arms front and rear, M3 sway bars, and M3 subframe bushings. E46 front guide supports. Euro tail lights.
09-07-2011, 11:20 AM | #3 | |
The mod bug has bitten.
22
Rep 565
Drives: 2008 M3 Sedan
Why are you unhappy with the BMWPS? I was thinking about this too. |
09-07-2011, 11:24 AM | #4 |
70
Rep 441
Thing is I don't have sport suspension at all, so I would need paired struts and springs for the right upgrade. Pricing the standard items I see talked about most - Eibach Pro/Koni FSD, thicker front sway bar (included in the performance suspension) - the BMW price is right there with aftermarket.
Why do you consider it a mistake? Thanks.
09-07-2011, 11:34 AM | #5 | |
91
Rep 1,324
Drives: 335i Coupe, 6 Speed
I was recently faced with the same dilemma where "my car's going under the knife anyways, why not upgrade all the suspension bits." I guess the upgrade will be limited by how much your willing to spend in addition to what your currently going for.
This thread is a great read. http://www.e90post.com/forums/showth...27#post3441727 Quote:
09-07-2011, 11:39 AM | #6 |
164
Rep 2,556
A huge consideration is your tires. Are you going to stick w/rft's?
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
09-07-2011, 03:05 PM | #7 | |
25
Rep 423
I'm not saying BMWPS is garbage. There are handling advantages to stiffer springs, people like them. I would suggest considering buying an OE ZSP suspension used. In addition to springs and shocks, you'll need front sway bar and bump stops front and rear. Possibly different front shock mounts, if your car's old? I forget. OE ZSP will lower your car by about 0.5" I think. BMWPS is reputed to lower 0" - 0.5" from ZSP, so up to 1" lower from non-sport. Personally I think that's too low, but many people think it looks pretty. OTOH, the performance kit is changed since I bought it, maybe they fixed some things...
09-07-2011, 03:24 PM | #8 |
127
Rep 6,773
All of em IMO..the issue w doing a few is it will hi-light the weaknesses in the areas you dont do..and also when using these proper coilovers and LSD are a must
The complete M3 list: Front Strut Brace Front Wishbone w/Headlight Regulating Rod Front Tension Rod Front Sway Bar Rear Guide Rod Rear Upper Link Rear Lower Camber Link w/Headlight Regulating Rod Rear Sway Bar Rear Subframe Bushings Toe Control Arm..is the only rear piece that cant be used off the m3. Megan Racing and Velocity Motorcars makes one thats good. Incidentially..I have just looked at the pricing and these m3 bit have skyrocketed since last year when I purchased.. which really sucks for new buyers..all around it is an expensive proposition..by the time you are done you will be in $7K territory |
09-07-2011, 08:54 PM | #9 |
70
Rep 441
I've been looking at realoem.com for the parts you guys are mentioning and the terminology is different, and I'm a bit of a suspension novice so I don't know how to translate your terms to realoem to order parts. For example, the following terms are not found in the M3 suspension pages HERE or HERE:
tension link (is it the tension *strut*?) sub frame isolator bushings control arm about RFT's - I will replace them when they wear out, whatever upgraded suspension I decide on will be there before the RFTs are gone. I'm looking for basic handling improvements: tighter more precise steering, conservative drop, less brake dive. Car won't be tracked and I live in the NY/tri-state area so I *may* stick with 17" due to pothole concerns especially if I go with the performance suspension because I know its lower and tighter than ZSP. I'm not particular about the technical subtleties of various suspension dynamics, I just want my car tighter, lower and more "flickable" while maintaing decent comfort. Put another way, if I had to do it over again I'd get ZSP and not think twice. If I could find a very low-mileage full ZSP suspension for my exact car I'd go that route, but I haven't found it yet and I'm a little hesitant to piece together used suspension items out of concern for exact fitment and a less-than-satisfying end result So maybe the OEM performance suspension is overkill for my modest requirements, but the piece of mind of brand new, BMW-warrantied parts and installation is worth something to me as well. Thanks for the input. Howard
09-07-2011, 10:16 PM | #10 | |
164
Rep 2,556
The M3 front control arms and rear subframe bushings tighten up alot of the slop in this car BUT will be pretty harsh with rft's, so I'd wait to do those. 'Flickable and decent comfort' don't really go together. Lot's of folks are happy with the reduced roll, dive and squat of the BMW perf susp, but imho the non-M3 BMW dampers suck. Another option, which I like, is you can buy slightly used zsp spings for cheap and pair them with Koni sport dampers. I don't know what sway bars came on your car, but the rear arb install is expensive unless you do that in conjuction with the rear M3 subframe bushings, which is 4-6 hrs labor. g/l
09-07-2011, 11:17 PM | #11 |
16
Rep 378
tibra, I know I've already asked you...but please post what you sent me. The first m3 bits to buy for those with a budget that give the most positive feedback vs. cost. I believe you said front control arms and rear bushings? If you have LSD, then front AND rear sways. I'm not sure how affective just adding m3 front sway is alone w/o rear.
09-07-2011, 11:24 PM | #12 | |
127
Rep 6,773
Doin the rear subframe bushings also presumes you have coilovers already..the OEM suspension will not be able to handle the stiffer subframe bushings... My order of priority would be: Tires Coilovers M3 Front Arms / Sways Rear Subframe Bushings Rear Arms/ Sways LSD |
09-08-2011, 01:28 AM | #13 |
164
Rep 2,556
^ What parts of the oem suspension will not be able to handle the stiffer subframe bushings?
09-08-2011, 02:42 AM | #14 | |
25
Rep 423
tighter more precise: springs, shocks, subframe bushings conservative drop: springs obviously less brake dive: shocks I think the ZSP equipment will address your needs very well. I have only driven in a non-sport a short time (when shopping for the car), but it is very soft. Be careful lowering the car below ZSP level. Look into "bump travel" or "compression travel" and make sure you have enough. These cars can be lowered, but it's tricky to do it well. For example: coil bind. Let's say you lower the rear to 13.5". In the rear of our cars is an approx. 12" spring that operates at about 7-9" long compressed while driving. At 7" the spring is quite nonlinear and at 5.5" it coil binds. But the bump stop limits travel before coil bind occurs. (I am making up these numbers but they are within 0.5" of the truth.) So, let's say you lower the car and find you lack travel, so you shorten the bump stops or use a short body shock in order to get more travel at the shock. Now you risk coil bind because you're allowing the spring to compress more than before. In the front, there's also the roof of the wheel well to worry about at some point, and the bad geometry of the struts. At a point in its compression arc the front wheel starts tucking inward. Meantime the bump stops are being partly triggered because of short travel space, throwing your car around and making your life miserable... So, I'd be careful going below ZSP height.
09-08-2011, 02:45 AM | #15 |
127
Rep 6,773
The OEM springs/dampers..w such a low spring rate they will be working overtime to compensate for the stiffer subframe bushings..the biggest benefit hands down will be upgrading to coilovers..modding other points in the car w/o addressing this would be counter-intuitive
09-08-2011, 02:54 AM | #16 | |
25
Rep 423
The M3 front bar is a tiny bit stiffer than the ZSP front bar.
09-08-2011, 02:58 AM | #17 | |
127
Rep 6,773
The M3 bar maybe slightly stiffer than ZSP but I assure you the M3 sway bar bushings are MUCH stiffer. |
09-08-2011, 06:26 AM | #18 | |
70
Rep 441
What specifically did you dislike so much for you to call it a '$1,000+ mistake'? Thanks.
2009 E90 328i Montego Blue, Black Leather, 6MT, ZPP, Logic 7, HD radio, CA, fold-down seats, PDC. ED pickup 6/12/2009 mods: Koni FSDs, Eibach Pro's, Sport/Heated Seats, BMW Perf. short shifter, M-tech shift knob/e-brake handle/steering wheel, split armrest, black grilles, 50% tint, 3M clear bra. Last edited by hdrewh; 09-08-2011 at 07:39 AM.. |
09-08-2011, 09:56 AM | #19 | |
70
Rep 441
Thanks.
09-08-2011, 10:09 AM | #20 |
25
Rep 423
Because...
The shocks are weak, the springs are higher rate than I need, and my car is upset over majority of bumps.
09-08-2011, 10:14 AM | #21 |
25
Rep 423
I think whoever told you that was pulling your leg, tibra
09-08-2011, 10:15 AM | #22 |
25
Rep 423
hpautowerks.com
