low rpm problem
09-06-2011, 06:14 PM | #1 |
34
Rep 1,118
low rpm problem
well when im driving 1-3rd gear is find since its higher rpm in those gears i have no problem but in 4th 5th and 6th if its like 1k to 1.6k rpm and i give it gas it feels like the whole car is shaking and u can hear the intake sucking and stoping on and off. rpms jump up and down couple hundred and after it hits over 1.6k rpm its perfect.
i think it might be the throttle body but im not sure so just asking. |
09-06-2011, 06:18 PM | #2 |
153
Rep 3,730
When was the last time the coils, injectors, and plugs were changed? Any codes come up?
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-06-2011, 06:31 PM | #4 |
184
Rep 2,320
how many miles u have on your car?
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
09-06-2011, 07:40 PM | #6 |
153
Rep 3,730
Have them take another look at them (coils, injectors, plugs). Also, a good intake valve cleaning my help too, after 60K I bet they are pretty gunked up.
09-06-2011, 08:23 PM | #9 |
124
Rep 1,362
How do you justify just replacing one plug with 60k miles? Maybe the DME needs to readapt to that plug/cylinder as it was used to that plug running shitty.
09-07-2011, 09:30 AM | #11 |
369
Rep 8,693
Drives: 06 330i
downshift?
09-07-2011, 09:47 AM | #12 |
3441
Rep 79,211
Replace all the plugs. I never heard of someone replacing just one... they are so inexpensive just replace all.
If the car hasnt had updated HPFP, or injectors those could pose a problem as well. However,I think its the plugs they should all be replaced around 20-25K. |
09-07-2011, 11:58 AM | #13 |
30
Rep 288
That's like shitting your pants, wiping your ass, and putting the same underwear back on...
G42 M240i xDrive
