Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Easiest way to Remove 3m'd Aero Lip?
      09-05-2011, 08:47 PM   #1
Focus
68
Drives: N/A
Hey guys,
what's the easiest way to remove my aero lip from my E92? I'm positive it's held on by double sided tape as i' was able to remove a corner but it seems as if removing the entire thing is gonna be a PIA. Local shop wants to charge me $100 on top of the price they're charging me to repaint it to remove it and put it back on.
Any suggestions would be greatly appreciated, thanks!
      09-05-2011, 09:25 PM   #2
JS82
JS82's Avatar
Drives: '08 E92 328i 6MT Jet Black
Try to heat it up with a blowdryer or heatgun and use some floss.
      09-05-2011, 09:28 PM   #3
GetSomeE92
Drives: '09 Space Gray E92
Go buy some 3M adhesive remover. Spray it on, let it heat up in direct sunlight, remove. Easy.
      09-05-2011, 09:35 PM   #4
Focus
68
Drives: N/A
Have you done this before? would i have to heat it up myself?
      09-05-2011, 09:35 PM   #5
Focus
68
Drives: N/A
Tried blowdryer. Waaaaaaay tooo slow, would take 4+ hours just to take the thing off. Also tried Floss with that blowdryer and none would last long at all, kept breaking.
      09-05-2011, 09:37 PM   #6
GetSomeE92
I have, and it works. Sprayed it on the adhesive and let the car sit facing the sun for several minutes. Was able to take it off.
      09-05-2011, 09:39 PM   #7
Focus
68
Drives: N/A
How were you able to spray the center section. I might try this tommorow.
      09-05-2011, 09:42 PM   #8
GetSomeE92
Use one of those thin straws. Also, it is easier once you get the sides loose.
      09-05-2011, 09:53 PM   #9
Focus
68
Drives: N/A
Ah, good stuff, i'm going to give it a shot next day off i have, thnx alot !
      09-05-2011, 09:56 PM   #10
GetSomeE92
No problem,bud. Hope it works for you.
