misfire cylinder 1
09-04-2011, 05:04 PM | #1 |
Rep 13
misfire cylinder 1
ok without writing 5 paragraphs ive had plenty of idle and running issues with my 08 335i... The dealer I go to sucks so I want to make that last resort. I threw code 29CD - misfire cylinder 1! Dealer replaced Hpfp and injectors 1, 2, and 3 (hassle). car is out of warranty! I replaced plugs with Iridium NGK's... what could be the problem now? Coil pack?
Thanks |
09-04-2011, 05:16 PM | #2 |
164
Rep 2,875
You can try to switch the coil pack from cyl. 1 to either 4,5, or 6 and see if the misfire follows.....
Why did you switch to Iridium NGK's? Do you have upped turbos? Most people recommend OEM Bosch.
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
09-04-2011, 05:20 PM | #3 |
Rep 13
Yea everybody on the forums recommend oem bosch, I had all my buddies chirping in my ear about how good NGK's are lol so I ended up going with them. And good idea i will try switching the coil pack my mind isnt working today lol thanks man!
09-04-2011, 05:22 PM | #4 |
164
Rep 2,875
NP!
BTW, did you notice any difference in idle/performance after switching to the NGK plugs? Just curious.....
09-05-2011, 02:56 AM | #5 |
Rep 13
honestly i didn't notice an idle difference other than the car idling normally after the old plugs were switched... they were shot. Also, another reason i switched to the iridium ngk's was becuz some guy was talking about the carbon buildup from the bosch ones haha idk how true it is tho.
09-05-2011, 03:04 AM | #6 | |
127
Rep 6,773
09-05-2011, 08:56 AM | #7 |
Rep 13
You're prolly right I just wanted to see what these things would do, ill end up switching back to bosch soon. Thanks for the input and hope you dont have to deal with that!
09-05-2011, 10:51 AM | #8 |
10
Rep 375
You should definitely stick with OEM plugs. If problem is still present try switching coilpacks and see if the misfire moves. That should answer your question if it does move.
09-06-2011, 01:49 AM | #9 |
Rep 13
thanks everyone for the input... i found out its the coil pack since the misfire moved with it and i will be ordering a new one this week. I really dont need to swap all 6 so ill prolly buy 2 or 3 just to have a couple spares. ne one have ne sites i can order them off ecstuning is all ive found so far.
thanks again!!! |
09-06-2011, 06:19 AM | #10 |
24
Rep 1,244
