PWM/Helix/DCI Holiday
09-04-2011, 04:24 PM | #1 |
Rep 277
Thanks to Robert at Vishnu for getting my 2.5 upgrade and meth kit to me by the weekend. I've had my Helix IC and DCI sitting around for over a year and a half and finally got around to putting them in this weekend, along with PWM and 2.5 Procede update. It had been as long since I was in the ECU box so I had to update the harness wiring for the 02 change here. http://www.e90post.com/forums/showthread.php?t=450494
and the PWM harness change. The Helix IC was done on jackstands and required no cutting and amazingly it slid up and in on the first shot. Two sets of hands is a must, three is even handier. 60k miles on my car and only a few drops of oil in the OE IC, what a tiny piece of crap. PWM kit was pretty straightforward. Hardest part for me was last connection on the charge pipe to the manifold hose, but with work it gets there. I cleaned up the wiring and tubing with some extra loom I had laying around. Pictures attached. I'll post some logs later as I data logged the wrong channels. My user map settings were as suggested by Vishnu in PWM manual using 7-29 AT autotune map. We followed Procede instructions and she started up first time, well first time after realizing I forgot to hook up a power wire in the ecu box. After driving it all I can say is N54 and Vishnu is the gift that keeps on giving. This will be the 3rd or 4th time I've felt that the mod made the car feel brand new in an amazing way. The car is very, very, fast(kinda spooky fast on the top end, it never ends) and seamless in meth integration. Good job guys. Happy is Happy |
09-04-2011, 08:09 PM | #2 | |
184
Rep 2,841
Top end just keeps on going and doesn't fade whatsoever, while the switch to the meth map is seamless. Car is deceptively fast but at the same time so smooth. Gotta agree that chargepipe is the hardest part of the install......but well worth it. |
09-04-2011, 08:15 PM | #3 |
8
Rep 476
Seems kinda pointless to use on the street doesn't it...you're in the triple digits without much thought at all. Car will be back to map 1 come Tuesday. Don't want to press my luck and end up with any tickets or in handcuffs
09-04-2011, 09:02 PM | #4 |
Rep 277
Have to agree, it's like the first time I drove my son's SC Saleen Mustang at 500 rwhp (it's now mine) can't say I was scared but it just requires more attention and keeps your heart thumping at a different level. It's a serious ticket in the waiting if I keep flashing those meth lights.
09-18-2011, 06:07 PM | #5 |
Rep 277
Streets dried out enough to get a log with the following. I let it shift at redline.
FBO's except DP. 7-29 Autotune map AT 92 octane 68 degree ambient 65 ut 0 ic All DTC off. The runs felt good, my gauge showed consistent max 17 psi pulls. I think the log looks OK but not sure what the meth flow drop out is at about 5500 and 6600 rpm. Anything look out of place on this log? Last edited by happy4nk8er; 09-18-2011 at 06:31 PM.. |
09-18-2011, 06:26 PM | #6 |
3441
Rep 79,211
Thats why they have Mexico or drag strips
09-18-2011, 06:59 PM | #7 | |
I sweat pheromones
203
Rep 2,103
In fact, not to go off on a tagent but I thought we needed the Vishnu charge pipe as it originally had the pressure switch. Once I opened the package, I realized they made it completely separate meaning you could use any charge pipe. I realize there all supposed advantages for the large pipe but if I could do it over again, I would have gotten an easier to fit chargpipe. Live and learn. I now must do some logs. Although the car feels great, I'm curious to see if I'm getting similar timing drops. Seems to be somewhat common. However, even if that's the case, I'm not worried. This car feels great as is. The olast power mod I need is downpipes but I vow to only do that when my warranty expires. |
09-19-2011, 10:24 AM | #8 |
Rep 277
Shiv any comments on meth drop out? Air bubbles? Should I back down to aggression level 1 from 2? I really don't want to run 17 psi without DP's I'm thinking.
09-19-2011, 11:21 AM | #9 |
184
Rep 2,841
I'm running 16 psi without DP's.
Your meth flow doesn't look smooth and perhaps a little too low.....but it doesn't seem to affect your timing curve - that looks great! I think the meth pump duty cycle should sit around 80 until close to redline when boost tapers off, then it probably drops a bit to compensate for less boost. But that seems like a large drop in your pump duty cycle to me and it correlates to a simultaneous spike downwards in your meth flow. Perhaps a partially clogged filter on the WW resovoir? Here is my datalog from a couple of days ago.....but I am running a couple of degrees of ignition correction. My meth flow seems a bit more stable than yours, but earlier last week, my flow rate looked pretty much like yours for a couple of days. I pulled the meth line off the pump and bridged the boost switch and it flowed just fine....so I pulled the injector nozzles and blew them out with some air and all has been good so far. |
09-19-2011, 12:57 PM | #12 | |
Rep 277
09-19-2011, 01:17 PM | #13 |
Rep 170
I've been told by BMS when you install the DCI you need to make sure you measure the amount of pipe that gets inserted into the filter and that they're only in 1/2".
Maybe you cut them down or used different pipes entirely but in your pics they appear to be in very very far.
08' 135i MT || Cobb Stage 1 'Aggressive' 4.01 Map | BMS DCI | Berk Mid Pipes | Maddad Eurosport Axleback | E93 FSB | M-Sport Black on Black | CDV Delete ||
09-19-2011, 01:45 PM | #14 | |
Rep 277
09-19-2011, 02:34 PM | #15 |
Rep 170
ah OK, typically when I'd seen someone say "DCI" they were BMS, I didn't know Vishnu had a product of the same name.
