Anyone else experienced a boost leak after installing PWM?
09-03-2011, 11:46 PM | #1 |
29
Rep 1,551
Its friggin annoying. I was hitting 14psi just fine yesterday. After installing the PWM kit, I could't hit more than 11.5-12psi on both map 4 and map 1. I redid the entire charge pipe and coupler section again and torqued the hell out of them. No dice.
The wastegates are fine, the only aftermarket couplers are on the new charge pipe, and DV valve offset tubes. I guess I need to pressure test. I have a stock FMIC, but could those connections leak? I may put together a small leak test like Sniz who pressure tested from the hot side of the intercooler. I'm just trying to think of a way to connect a coupler to the stock FMIC without damaging the disconnect. Anyone got any ideas of how to connect a pressure fitting to the stock snap-type ring connectors? EDIT: the leak was at the intercooler, snap coupler shook loose. Goddamit. Last edited by Tzu; 09-04-2011 at 12:18 AM.. |
09-04-2011, 01:30 AM | #2 |
I sweat pheromones
203
Rep 2,103
Before reading your edit, I was thinking to check there. I experienced the same boost leak, although not during the pmw install. If you only spent 30 minutes on the problem, consider that a win.
09-04-2011, 07:45 AM | #3 |
158
Rep 1,288
Drives: 2014 435iX, FBO
+1... also, did you change the Diverter Valves? that will be your next leak if you didn't - may only be needed if you upgrade the FMIC
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
09-04-2011, 12:26 PM | #5 |
79
Rep 1,682
this probably re-assures my problem with my BMS meth kit.
I cannot boost anywhere more than 11 lbs and i believe its something to do with my intercooler. But not having a garage to work with limits me checking there so im just waiting to purchase a new FMIC and hopefully when thats installed, fixes my problem. |
09-05-2011, 01:15 AM | #6 |
29
Rep 1,551
