Need some help deciding what tires to use!!1
09-03-2011, 04:57 PM | #1 |
"See me.. now you don't"
16
Rep 289
Hi all
I bought a new set of whees and the rear specs are 19x9.5 rear et 43 I have two set of tires for the rear in my garage and I need some help deciding which ones I should use to avoid any rubbing issues etc. I have a set of : 275/30/19 and 265/35/19 WICH ONES SHOULD I PUT ON..??? Thank you in advance |
09-05-2011, 02:01 AM | #4 |
16
Rep 289
Im trying to figure out which size tires to use. ( i have them already)
No i will not be using them on the winter.. im more worried about rubbing issues/etc. So trying to see which size will work better with my new wheels. |
09-05-2011, 02:47 AM | #5 |
127
Rep 6,773
I believe 265-35-19 will have too big of a side wall and may rub the sidewall is a .4 in larger..also w 43mm offset wheel will be tucked in and not flush..
You can use this calculator to see www.rimsntires.com/specs.jsp 265-35-19 Sidewall 93 mm (3.7'') 275-30-19 83 mm (3.3'') |
