Procede PWM kit and road course
09-03-2011, 03:15 PM | #1 |
I sweat pheromones
203
Rep 2,103
This is not another PWM review but instead an inquiry.
I drive an AT. AT plus 20 min road course sessions = heat = reduced power. That's one of the biggest factors for getting a PWM kit. I wanted the cooling effect and liked the fact that it would kick in without the need of WOT. Now, I believe I'm in the minority when it comes to putting a car on the track. Vishnu's PWM recommendation below looks good for the street. However, I don't think it would work well for the track. Running 16.5 boost can't be good for an extended length of time. And frankly, that much power isn't necessary. So, my question is this: What settings would you run on a road course? What would you recommend for both Maps 1 and 2 in case I run out mid-session? Again, this is not for 1/4 or street. I am not looking for max power. Here are my engine mods: V5 2.5 (7/29), PMW, DCI, ETS 5" (Correct, I am running stock DP) Procede PWM recommendation: |
09-03-2011, 08:38 PM | #2 | |
158
Rep 1,288
Drives: 2014 435iX, FBO
You listed all the default settings, it worked for me. I am data logging now and asking Shiv how we know what % meth injection is to tooo much - I need to to know what to look for in the logs so I don't bog the motor I figure. I will bump it to 30% or 40% injection and see if that feels better up top. I want to see the logs show a difference though, I think Input Air temp will be a key figure. If you have FBO, to to 17 PSI and tell your grandma you will pick her up in your wife's car..... BUMP IT UP and let her RIP !! it is addictive EDIT: Sorry, I thought you had FBO... you don't - I think your boost is right. Go get an intercooler...
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
09-03-2011, 08:39 PM | #3 |
158
Rep 1,288
oh, on Map 2, put your traction control setting to 30%.. big difference.
09-04-2011, 01:41 AM | #5 | ||
I sweat pheromones
203
Rep 2,103
Got the IC. Basically, I'm FBO minus the downpipes. Quote:
Still crazy as in too much power? Did you reduce boost? How long were the sessions and how long did the meth last? |
09-04-2011, 07:16 AM | #6 |
161
Rep 7,377
This. I personally run the ring at 15 psi and was plenty. Temps were 126 C oil and 107-109 C water. Even with meth your temps will go up a lot.
09-04-2011, 07:51 AM | #7 | |
158
Rep 1,288
Don't get me wrong, there is a HUGE difference with the rear end now with the LSD... massive change in the car for sure as you know. If I am going off the line WOT, I will usually hit DTC once and let TC take it from there... certainly too much power in first without careful application.
09-04-2011, 10:52 AM | #8 | |
112
Rep 4,771
My point wasn't to set a certain psi that I recommend but rather just to say that your boost should be dependent on the type of track you are on. Generally, the tighter it is, the less power can be used effectively. I enjoyed my car much more at low boost on that course simply because I didn't have to worry about spinning as much. |
09-05-2011, 10:32 PM | #9 |
I sweat pheromones
203
Rep 2,103
Well, I'm hitting the track Wednesday morning. I think I'll set map 1 to 12psi. Map 2 for 14psi with meth. I'll see if there's a benefit. Very curious about temps. We shall see.
Any other opinions on the topic? |
