Re-dyno at Surgeline
09-03-2011, 02:39 PM | #1 |
164
Rep 2,875
Went back to Surgeline today and re-dyno'd my car. Last time around, I had 4-5 timing drops running 16 psi. This time I tuned it down a little. Let me know what you guys think.....Could I have ran more boost, like 15-15.5 psi?
Procede settings: 14.5psi IC 100% Auto-tune off All else are on default Car: FBO 92 oct, no meth Temp.: ~75 degrees, ~46% humidity Here is the dyno and the datalog:
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
09-03-2011, 03:11 PM | #3 |
164
Rep 2,875
LOL......must be, it's Shell 92 oct, which is what I've always put in my tank.
Wonder if Chevron would be a little better?
09-03-2011, 03:16 PM | #4 |
177
Rep 6,631
try all the various brands. IMO Shell is overrated. The stuff is 10-15 cents more expensive here for no real good reason. I put pretty much any 93 octane gas I can find, from Sunoco, BP to Gulf and I never had those kinds of timing drops at that boost level with your mods.
E90 LCI N54 6AT
09-03-2011, 03:22 PM | #5 |
ElevenPointFive
326
Rep 2,450
Cant read the results, pic too small for my old and tired eyes
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
09-03-2011, 03:36 PM | #6 |
164
Rep 2,875
Here ya go....
09-04-2011, 01:31 PM | #8 | |
164
Rep 2,875
Anyone else care to chime in? Team Vishnu? TIA
09-04-2011, 01:37 PM | #9 |
164
Rep 2,875
Also, this is unrelated, but I'm used to dynoing in 4th gear, but this last dyno was done in 3rd.....Well, he did a 4th gear run first, and said that the readings were too high? I don't have the printout or the file to that first 4th gear run. But I believe it was around 405 tq/380 hp, or very close to those numbers.....So IDK.
He also mentioned that all the dyno runs that were done in Texas (their HQ?) were done in 3rd gear.....
09-04-2011, 07:08 PM | #10 | |
Rep 158
09-05-2011, 12:16 AM | #11 |
164
Rep 2,875
Changed it back to what? I thought the default IC setting is 100%?
So you're saying when your IC was at 100, you see timing drops? And when you lower the IC there were no timing drops? I thought it was the other way around, no?
09-05-2011, 12:24 AM | #12 |
Rep 158
I thought the default was 50. I could be wrong.
09-05-2011, 12:25 AM | #13 | |
Rep 158
I changed something from 50 to 100 and I saw timing drops I forgot the setting and I'm not at home to check. |
