MS-8 EQ Settings? System sounds awful
09-03-2011, 10:46 AM | #1 |
9
Rep 184
I have finally finished my system install after having to return the first MS-8 that was DOA.
After running the sweeps and adjusting gains on the amps everything sounds worse than stock (except now I hav base from the 10w6). I know I need to play with the EQ settings some, but not sure where to begin. Can someone post their EQ settings they are happy with? AMPS: JL 600/6 JL 600/1 MS-8 Setup: CH 1. -> AMP -> OEM Door L CH 2. -> AMP -> OEM Door R CH 3. -> AMP -> SSMB8 L CH 4. -> AMP -> SSMB8 R CH 5. -> OEM Center CH 6. -> OEM Rear L (in parallel) CH 7. -> OEM Rear R (in parallel) CH 8. - AMP -> 10in Sub (10w6) Sub low pass: 80HZ Front Low/Hi pass: 170HZ Center Hi pass: 150HZ Rear Hi Pass: 150HZ After all these settings and the EQ flat, things sound awful.
2009 e92 335i 6spd :: Black Sapphire Metallic :: Coral Red :: Work Gnosis GS4 Wheels (20x8.5+32/20x9.5+35) :: Bronze Rays Lug Nuts :: AngeliBright v3 :: PROcede v4 :: Injen DCI :: Clutch Stop :: B&G S2 Sport Springs :: Matte Black Kidney Grilles :: Tinted Taillights :: Escort Passport 9500ix :: Samsung S1 160GB HDD
09-03-2011, 11:21 AM | #2 |
300
Rep 3,969
Calibration volume?
Sweep volume? (how loud and are the sweeps consistent) Do you have a centered image? Do you hear distortion? (from where) What inputs? (HiFi, L7 or base) Do you have HU EQ/Processing defeated?
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
09-03-2011, 11:26 AM | #3 |
9
Rep 184
I've tried to follow the various guides posted on this site.. I have the L7 system, and I calibrated at ~48clicks and -20dB on the MS-8.
I don't hear any distortion. The system sounds like it is playing over a PA system. At low volumes its ok, but the higher the volume the worse the sound gets. The HU EQ is flat and L7 turned off.
09-03-2011, 01:52 PM | #4 |
2288
Rep 13,001
Try:
- Calibration volume -45dB - Front low/hi at 150Hz at -6db - Center at 160Hz at -24dB - Rear at 150hz at -24dB - Sub at 80Hz at -18db with subsonic at 20Hz at -24dB - MS-8 volume after sweeps -10dB |
09-03-2011, 02:48 PM | #5 |
300
Rep 3,969
Since you're running the sides off the MS-8, I can tell you that the calibration volume MUST be under -30dB. Anything louder will cause distortion and/or clipping of the mics. -35 to -45 should be the range you want to try. You also MUST adjust all amp gains such that the individual sweeps are roughly the same volume as the sides. Make the adjustments using the first sweep of each seating position, since it sweeps the underseats separately from the doors. You'll probably have to do this a few times until you get it right. Oh and the sub.... forget about level matching. Just set the amp gain such that you can barely hear the sub sweep. You definitely don't want to feel it, otherwise it is too loud.
09-03-2011, 05:49 PM | #6 | ||
9
Rep 184
02-01-2012, 03:30 PM | #7 |
8
Rep 75
I followed the recommendations, and when I calibrate at lower levels (-45 for example) i get huge distortion in the speakers at low volume level after. It is actually better when I calibrate with higher volume. But it still isn't "great". I did setup the cross overs as above. Just curious, is there a way to completely bypass the MS-8 for testing purposes? (with out actual wire changes)
my setup is the following: stock HU (hifi) MS-8 (obv) 600/1 600/6 channel list: 1) SL, stock rear left (MS amp) 2) SR, Stock rear right (MS amp) 3) ctr, Vibe 4" 2-way (MS amp) 4) FLhi, DLS R4 (600/6) (bridged ch1/2) 5) FRhi, DLS R4 (600/6) (bridged ch3/4) 6) FLlo, SSMB8 (600/6) (ch 5) 7) FRlo, SSMB8 (600/6) (ch 6) 8) Sub (12" JL for now) (600/1) Thoughts? |
02-01-2012, 03:54 PM | #8 |
300
Rep 3,969
My recommendations were based on MS-8 integration with Logic 7 OEM amp and speakers, which is totally different from what you have.
I would look at some of Technic's install posts (the ones that start with "notes on a...") as I believe your exact set-up has been done before. My guess is that your levels are mismatched, and that your calibration volume is incorrect.
02-01-2012, 06:36 PM | #10 | |||
281
Rep 4,121
My settings: Sub on Front low channel (shared with under seats) HP 20hz@24db Underseats HP 80hz@12db, Sub is LP 80hz@24db Front Low/Hi, 300hz@24db (Planning on moving back down to 200 or 250) Center HP 200hz@24db Side HP 200hz@24db Center + Sides on MS-8 power Best calibration...-21dB No kidding. If I had <-23 or >-20 it doesn't sound as good. I have some EQ in the 31 band on the very low freq's (20-40hz) and above 2.5k, to add some treble back to the MS-8's target curve. Results: A-MAZ-ING...no seriously...amazing. My commentary was that using MS-8 power for all channels, the target volume setting is -20, I have level matched my fronts and under seats within 6dB of my rears and within 3dB of my center, which is why i even bothered trying a higher volume. Just a different experience in my case. |
02-01-2012, 10:20 PM | #14 | |
281
Rep 4,121
02-02-2012, 01:10 PM | #18 | |
300
Rep 3,969
02-02-2012, 03:02 PM | #19 | ||
281
Rep 4,121
03-13-2012, 04:59 PM | #20 |
Rep 35
My ms-8 is setup as:
Sub -1 (channel 8) Infrasonic 20Hz Infrasonic Slope 24DB Sub/Front Xover 60Hz Sub/Front Slope 12DB Fronts 2way (channels 1-FL-Hi / 2-FR-Hi / 3-FL-Mid / 4-FR-Mid) Front Lo/Hi Xover 200Hz Front Lo/Hi Slope 12DB Center 1way (Channel -7) Hi Pass 160Hz Hi Pass Slope 24DB Sides 1way (Channels 5-RL / 6-RR ) Hi Pass 200Hz Hi Pass Slope 24DB I have the factory speakers and 2 HD 600/4s and one HD 750/1 with the gains down and I did the tune @ -42db. Then after I put the MS-8 @ -2DB. I still can't find the sweet spot, but I am close! |
03-13-2012, 05:13 PM | #21 | |
281
Rep 4,121
24dB slope all around? There are some phase impacts of using a 12dB slope which are of particular concern when using a center. I won't begin to explain it, but Andy has over on DIYMA. How do you like your HD's? |
03-13-2012, 05:28 PM | #22 |
8
Rep 75
Mine sounds terrible if I have the MS8 set anything lower than -22 or so when I do my calibration (JL600/4 and 600/1). Even with them set at mid gain levels. I do turn the sub amp gain down for calibration (way down).
My setup is: MS8 600/4 600/1 All 24db slopes front: DLS separates 200hz center: 4" coax, MS-8 power stock rear speakers @ 160hz (as sides) (MS8 power) kicker 8" woofers from 80 to 200 two JL 13" subs from 80 and down Only problem is I sometimes hear a little "scratchyness" (dont know how else to describe it) at high volume. (seems to mainly stem from the center channel) I did level match as best as I could before calib, cept subs. I turned them way down. |
