well my clutch is slipping.. time to upgrade thoughts ACT,CM,? need input thanks
09-03-2011, 07:56 AM | #1 |
14
Rep 290
What do most of you Manual cars run for upgraded clutches? and possibly flywheel also what are your thoughts and input guys?
i was looking at the ACT HD street clutch kit?? im running METH and will have full bolts in the near future as well
2008 135i 6-speed current stock for now
1995 e36 M3 5-speed Jb4 G5//CM-FX400//FBO//Meth// 12.06@118 6-speed manual sold summer 2013 |
09-03-2011, 08:06 AM | #3 |
14
Rep 290
the street clutch? or the 6-puck unsprung unit?
i know the street is rated at 465'ft lbs if i recall
09-03-2011, 08:26 AM | #6 |
Sees the world the way it could be
49
Rep 761
Look at SPEC's results on other platforms...their track record is poor at best.
ACT Organic all the way, can't go wrong.
09-03-2011, 08:27 AM | #7 | |
14
Rep 290
are you running a stock flywheel as well?
09-03-2011, 08:28 AM | #8 |
14
Rep 290
ACT is priced pretty fair among others also
09-03-2011, 10:46 AM | #9 |
61
Rep 1,120
I'm waiting for the day to come when I have replace the clutch but I'm leaning towards OEM as I like the feel and I don't think I'll ever be pushing more HP than Cobb Stg 1.
2007 BMW 335xi 6MT TiAg
09-03-2011, 10:55 AM | #10 |
36
Rep 332
My friend has the ACT organic clutch on his 135i FBO + meth + custom reflash. And yes, it is slipping after 5000 rpm.
He is thinking of purchasing the 6-puck ACT. Would this engage harder? Could it possibly cause a transmission failure? |
09-03-2011, 12:01 PM | #11 |
130
Rep 5,040
Lol have you ran a spec clutch before? Their stage 3 plus failed on me within 4 weeks with zero passes on the strip. Their customer service sucks as they left me out to dry. Do you need anymore information?
09-04-2011, 01:52 AM | #14 | |
57
Rep 1,054
I'm also about to choose a clutch and was looking for the ACT Street (with a organic disc), but now I'm not sure anymore... Maybe it's better to go for the ACT 6 puck instead? |
09-04-2011, 02:10 AM | #15 | |
127
Rep 6,773
Have a read what Mr. 5 wrote regarding ACT puck..its not for the street
http://www.e90post.com/forums/showth...ght=ACT+Clutch Quote:
09-04-2011, 03:01 AM | #16 | |
56
Rep 1,311
The ACT clutch has also been used at many digs from zero to high speed and never slipped so far. There are also a number of other users e.g. Mr. 5 who has been using the ACT clutch w/o problems. |
09-04-2011, 03:07 AM | #17 | |
57
Rep 1,054
It seems that the ACT Street is the best option for our cars right now. |
09-04-2011, 04:26 AM | #18 |
151
Rep 1,809
I also know someone with a slipping ACT clutch. But I don't see a better option right now. I went with an OEM clutch this time but although it isn't slipping, I can smell it after a few drag passes. In the future I think I will go with ACT too, but I don't expect miracles.
09-04-2011, 05:45 AM | #19 | ||
36
Rep 332
The ACT organic lasted for 9 months and after the first pull he cannot change gears after 6000 rpm because of slipping. personally I have the stock clutch which is fine so far (FBO + meth) but i'm not sure if it can handle this torque for long time |
09-04-2011, 05:50 AM | #20 | |
57
Rep 1,054
09-04-2011, 07:33 AM | #21 |
36
Rep 332
09-04-2011, 09:01 AM | #22 | ||||||||||
130
Rep 5,040
2)Its not my personal opinion - read up on the internet about SPECS reputation. Let me help you out: http://forums.audiworld.com/showthread.php?p=13549533 http://www.bimmerfest.com/forums/sho...d.php?t=102945 http://forums.vwvortex.com/showthrea...clutch-quality http://www.j-body.org/forums/read.ph...36&t=36636&p=2 http://forum.mazda6club.com/mtx-tran...h-failure.html http://forums.evolutionm.net/vendor-...ec-clutch.html http://mustangforums.com/forum/svt-f...h-problem.html 3)I have been driving stick for more than 6 yrs, not that it matters, so certainly I know how to drive. The spec clutch was broken in perfectly, according to the instructions they gave. 4)Since you can't google it for yourself, let me give you a technical breakdown of what happened or you can read it here: http://www.e90post.com/forums/showth...spec+clutch%22 - stage 3+ installed with brand new oem fly wheel - worked ok for the first while during break in period - was almost 90% highway driving, no launches. I broke it in properly since I just dropped almost 3gs including install and wanted this clutch to last and have some performance on the drag strip. OEM clutch went out after several track days, was not due to bad driving as you seem to assume (since you're are a tool). Only bad side effect was a ton of clutch shudder while engaging first gear. - about week 4 - spec clutch would require serious effort to disengage. Same issues as this guy from the link to the audi forum above - let me spell it out for you again to help you out since you are slow: Quote:
Here is some more feedback (from bimmerfest link above) describing the same exact issue I had, Quote:
