Has Anyone Installed the E92 Subwoofer Enclosure packages from Musicar?
09-02-2011, 10:27 PM | #1 |
12
Rep 191
Has anyone brought and installed E92 subwoofer enclosure packages from Musicar? How long did it take for you to receive the Sub-enclose? How was the sound quality? In case you do not know what I a talking about here is the link
http://www.e90post.com/forums/showthread.php?t=547361
If all else fails pull the handbrake.
09-07-2011, 07:44 PM | #2 |
12
Rep 191
Nobody? Well I have ordered mines and will hopefully post some pictures once I get it installed.
09-07-2011, 09:05 PM | #3 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
I know the E90 sub has been used by a few people, and the E92 looks just as good. I'm definitely going this route with my E90 as soon as I get some funds for a full package from them.
Did you get a sub and amp from them as well?
The i8 needs a V8 amirite?
09-07-2011, 10:11 PM | #4 |
12
Rep 191
Yep I got the Image Dynamics sub woofer and the arc amp. It is less of a headache in the long run since everything comes in one package and I do not need to go with the motion of buying a Technic harness, amp kit ect.
09-08-2011, 05:22 AM | #5 |
2288
Rep 13,001
If your system is Logic7 you will receive my harness with the VP Electricity sub kit.
09-13-2011, 02:55 PM | #6 |
she likes the flavor......
85
Rep 1,622
OP any update on this? Which package did you get?
E92 Montego Blue silfa718 ..::STETT CAI|ADVAN RS|WAGNER FMIC|MS DP|VANGUARD|PROCEDE|FORGE DV|BMS OCC|KWV2|MICHELIN PSS|OOS::.. |
09-13-2011, 06:04 PM | #7 |
Rep 6
@OP im curious to see how this went as well, im currently about to build my own 12" enclosure for my E90 similar to what VP has (Unfortunately i havent seen a 12" enclosure for E90). Was curious to see how you liked the output
09-20-2011, 11:25 PM | #8 | |
12
Rep 191
I got the Subbass Module Level One with amplifier. Update coming soon I am curious myself actually on how it will sound since not many people have a setup like the one given by VP Electronics. My package will arrive on the 22th so hopefully I'll get to installing it over the weekend, give some output, a picture or two of the install, and maybe a video if I can find time.
09-21-2011, 12:53 AM | #9 |
17
Rep 286
Drives: 2009 LeMans Blue Coupe
I've actually had the the sub box from Ken for a couple of months now. Got it in 12" with a Morel Ultimo sub along with Morel Dotech's for the door and the under seat subs. Got all of it from Ken. Unfortunately I've been so busy at work that I haven't had time to get it all put in.
09-25-2011, 06:35 PM | #10 |
12
Rep 191
https://lh5.googleusercontent.com/-T...0/DSC01140.JPG
https://lh6.googleusercontent.com/-9...0/DSC01142.JPG https://lh3.googleusercontent.com/-P...0/DSC01143.JPG So I finally install the system and it sounds pretty good, but I still have to tune it. Couple of pointers if your going to order and install this If you have a logic 7 system then you need to bridge it to 4 ohms, this means the 4 wires coming from the sub enclosure need to be twisted so they become 2 wires as oppose to 2. So you would twist the red and white wire together (these are the positives which need to go into the right positive of the amp) and twist the black and green together (there are the negative which both goes to the left negative slot on the amp). Tom from Musica who basically saved my butt but telling me this since i was putting 4 wires into separate slots that cause the amp to constantly go into protection mode. Another point is the bracket on top of the sub enclosure needed to be bent slightly in order to clear the latch for the folding seats (if you have one of course). Lastly would be that you need to route the remote wire from a power source like your cig lighters or as Technic prefers pin 10 on the back of the head unit. Other then that the install itself was very easy it was just the wiring from the sub enclosure which drove me insane for 2 days. The sub itself sounds amazing but I still need to tune it. Anyone who has installed a sub woofer, what freq do you goes usually keep it at in order to have nice low deep base? My only complain would be a little labeling what wires are positive and what wires are negative on the sub enclosure. I would like to thank Ken and especially Tom from Musica for helping me buy and troubleshoot with their product.
09-25-2011, 07:15 PM | #11 | |
687
Rep 6,845
Drives: 2018 Audi RS5 coupe
On my car, the sub was set to 55hz low pass And it sounded great Damn tight I'm not a fan of loose bass or ported boxes
09-28-2011, 11:43 AM | #12 |
22
Rep 221
looks clean! What type of LLC did you get to split the signal? PAC-SNI-35? And where did you connect the LLC if you went that route?
2008 e92 328Xi - Daily Driver
M-Tech Lip/ M-side Skirts/ Painted Grille/ 18" LM Reps/ BMS Powerbox/ Koni Sport/ B&G S2 Springs 2008 997.1 TT Porsche; 2008 Nissan Altima Coupe - Show Car; 1995 300ZX SMZ #36 |
10-04-2011, 06:58 PM | #13 | |
85
Rep 1,622
10-05-2011, 02:16 PM | #14 |
289
Rep 3,201
The amp that we use with our sub-and-amp kit has signal-sensing turn on, and so tapping the stock RTO wire at the back of the head unit is not required with Logic 7 or harman/kardon Top HiFi systems. (If you have an M3, then signal-sensing is not reliable with the woofer output of the EP amplifier). So I'm not clear why you needed a turn-on wire.
There is indeed a Technic harness in the kit. In the old days, we just included it - now we prewire the speaker and signal harnesses all into the Technic harness, so it's specifically modified for the kit you're getting. |
01-11-2020, 09:39 PM | #15 |
12
Rep 191
Man I thought my sub died the other day, it kept cutting out when the volume was above 75%. Turned out it was just a voltage regulators, popped a new one in and fixed the issue. Still enjoying the sub even though it is over 9 years old now.
Insane435477.50 |
