How much boost can the stock motor handle ?
09-02-2011, 12:15 AM | #1 |
15
Rep 178
Drives: 2009 335i XDrive
What are the stock internals rated for ? I see some over double stock boost levels here. How much until meltdown ?
2009 BMW 335i X-Drive
09-02-2011, 12:18 AM | #2 |
127
Rep 6,773
No one knows for sure..there is no rating..BMW will tell u anything overstock is unsafe..but then again the 335is has an overboost feature..I run 17psi..w no issues..you will inevitably need new turbos but engine internals should be good..the n54 has forged pistons and crank...the n55 doesnt so..?? only time will tell.
09-02-2011, 12:32 AM | #3 |
40
Rep 957
n54 07-08 models have been opened up and found to include forged internals including pistons. 09 and up im really unsure, but guys are making over 510whp with no motor issues so.. once fueling is all worked out people will eventually find out probably.
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle |
09-02-2011, 08:00 AM | #5 |
273
Rep 5,876
depends on what turbos you're running and where that boost is hitting in the RPMs, what sort of gas you're using, what sort of IATs your engine is seeing and how much exhaust backpressure you've got...its all "relative"
excessive heat and low octane is what melts engine internals not necessarily boost itself |
09-02-2011, 09:09 AM | #6 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
I'd say 14-15 PSI is a conservative limit on 93 octane pump gas for turbo longevity if you don't have full bolt-ons. Opening things up with downpipes, FMIC, etc. might make 17 PSI safe, but it's hard to say. A lot depends on how your tune compensates for the inceased power with higher water pump speeds, timing maps, etc.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
09-02-2011, 05:28 PM | #7 |
driver mod in progress
225
Rep 1,858
Drives: with both feet
I'll second Dzenno, and roundel's guess is the same thing I'd say.
09-02-2011, 05:47 PM | #8 |
13
Rep 377
28.768312098 psi
2007 335i Coupe 6AT - Sports Package - Premium Package - Procede V5 Rev 2.5 - Vishnu PWM - Vishnu DCI - Vanguard Exhaust - AR Downpipes - Helix FMIC - 19" Avant Garde M6 Reps - Michelin Pilot Super Sports - Bilstein PSS10 - M3 Suspension Bits - M3 Sway - M3 Strut Brace - GP Thunder -Forge DV -15% Tint - Aero Lip
09-03-2011, 11:18 PM | #10 |
15
Rep 178
09-04-2011, 12:57 AM | #14 |
127
Rep 6,773
09-04-2011, 07:53 AM | #15 |
Some say...
239
Rep 4,296
Drives: Fresh
I still can't believe BMW went cheapo on us. BUT at least I made it in time and got me a 2007.
I have exhaust and an intake... |
09-04-2011, 08:51 AM | #16 | |
158
Rep 1,288
Drives: 2014 435iX, FBO
Question: Does the 335is, and the 1M have forged pistons and the "good" motor? anybody know... (probably thread jacking here....) On topic... I would say that the data logs will provide the basis of how far we can go. I will also point out that we have some members with huge boost going with upgraded turbos... we are not seeing any blown motors, and some people have been running this for a while. 20PSI for sure.... Fuel limits seem to be the natural cut off, not seized bottom ends of the motors due to increased stress or pushing too hard.
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
09-04-2011, 12:22 PM | #17 |
13
Rep 377
oh yeah, my bad..i was just rounding it off to the nearest whatever that is..hahahahaha
09-04-2011, 12:30 PM | #18 |
13
Rep 377
09-04-2011, 02:59 PM | #19 |
8
Rep 330
Where did you read that the early N54 pistons are forged? I've been lurking around, but haven't found anything convincing. I have a 2007 335i.
09-04-2011, 03:09 PM | #20 |
161
Rep 7,377
They are. My engine had and still has forged internal after rebuild.
09-04-2011, 03:59 PM | #21 |
40
Rep 957
from this guy lol^ as well as e92fan whos motor was opened
