Mr.5 Intake: e92 fender brace question
09-01-2011, 08:21 PM | #1 |
My X5d tows my spec miata to the track.
74
Rep 1,254
EDIT: logs posted in post #15.
Here's my Mr. 5 intake setup. I finished it tonight. I happened to have a K&N 3.5" filter in the garage so I just used it - which required a 3.5" joiner, 3.5"-3" reducer, and 3" joiner. Maybe I should have just bought a 3" filter... I yanked the brake duct and black plastic behind the grill for airflow and fitment reasons. it was pretty straightforward because of the great description of the original and the numerous other setups. The one question I have is about the fender brace that e92s have. I could squeeze the tubing btw it and the fender liner but it was VERY tight. I removed the brace and am wondering about the effects. Has anyone else installed a Mr. 5 intake on an e92? WHat did you do about the brace? I'd appreciate any advice. Last edited by boom; 09-03-2011 at 06:14 PM.. |
09-01-2011, 10:08 PM | #2 |
74
Rep 1,254
Said brace passenger side:
Intake side: It mounts to the frame under the coolant hose and at the fender infront of the powersteering reservoir. |
09-02-2011, 06:16 AM | #5 |
74
Rep 1,254
09-02-2011, 06:16 AM | #6 |
74
Rep 1,254
09-02-2011, 08:45 AM | #7 |
25
Rep 294
Dude, put your car back together. Do you think those ducts and braces are there needlessly? All this for what, 5 horsepower?
2012 X5 35D - Platinum Gray / Cinnamon Options: Sport, Tech, Cold Weather, comfort seats, leather dash, high beam assist, lane-departure warning, soft-close doors, two-row, self-leveling suspension, hi-fi stereo
Tracks driven (in any car): Nürburgring Nordschleife (05/2011), LeMans (ok, just the public part), Eagles Canyon Raceway, MotorSport Ranch Cresson, COTA Austin |
09-02-2011, 09:43 AM | #9 |
74
Rep 1,254
Actually I think it's closer to 20 hp and I'm not exactly sure that those items are that important just because they're on the car. For example, do you think two DVs are necessary? EGR is only for emissions. The pcv routed to your inlet only serves to gunk up your head. do you really think 4 catalytic converters are necessary for a car running 13 AFR at redline stock? How about your seatbelt reminder?
09-02-2011, 09:44 AM | #10 |
82
Rep 2,325
What about in a collision situation?
| Andrew | M Technik | BMW Performance | BBS | Forge | V1 | LUX | Bilstein | Precision-Sport |
09-02-2011, 02:26 PM | #12 |
Rep 14
Clean solution...
Didier RC
www.milltek.fr |
09-02-2011, 02:30 PM | #13 | |
3442
Rep 79,211
Couple Scca guys actually praised the brake ducts on 335i. Especially when compared to the 370z which had nothing. (which is what ended up having car and driver/road and track) one of those guys crashing from brake failure. |
09-02-2011, 04:21 PM | #14 |
50
Rep 405
09-02-2011, 07:14 PM | #15 |
74
Rep 1,254
so in preparation for the intake i did a log of my stock car with COBB stg 1 93 octane tune. The outside temp was 78 deg that day. It was 77 deg today when I did the intake log. I did it on the same stretch of road to try an minimize differences. The logs follow.
You can see that the IATs with the intake are 15 deg cooler, boost is lower, I'm running more timing, it looks much more consistent, and the wgdc is lower indicating the turbos aren't working as hard. The throttle plate and boost are a little more erratic with the intake. That's not great but the stg1 tune is designed for a stock car and obviously the calibration isn't ideal for the improved air input capabilities. Such a good solution. Thank you Mr. 5. Last edited by boom; 09-02-2011 at 09:18 PM.. |
09-02-2011, 08:21 PM | #16 |
156
Rep 3,730
Actually the brake ducts are less than functional. They aim the air onto the tire, not the actual brakes. I left mine off on the custom intake.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-03-2011, 02:15 AM | #17 |
11
Rep 529
OP: Nice job again.
I wasn't aware that e92s had an extra brace. I would personally keep the brake duct. Even if the air is not aimed right at the rotor, I think the point is it keeps air moving through the wheelwell by displacing cooler air into it. I am not as familiar with e92s but can't you keep the brake duct but put a hole next to it for the filter? Another option would be to put a vent in the fender liner like the oil cooler. I am actually thinking about doing this. |
09-03-2011, 06:11 AM | #18 |
74
Rep 1,254
Thanks. I meant to also write that the car does seem to pull harder in the higher gears. There might also be a slight improvement in throttle response though that's difficult to quantify.
I'm going to see if I can get that duct back in there today. Last edited by boom; 09-03-2011 at 10:27 AM.. |
09-04-2011, 07:48 AM | #19 |
74
Rep 1,254
Got the duct back in yesterday without issue. Just took a little repositioning of the filter assembly.
With the logs and othe convincing dynos and vbox numbers this has to be the best intake for the buck around. I'd like to see how it compares to dinan. I'm surprised ar or bms or cpe haven't marketed a kit or core exchange setup for this. Seems like a no brainer considering all of the testing that has already been done. |
09-04-2011, 12:11 PM | #20 | |
124
Rep 1,362
09-20-2011, 10:17 PM | #21 |
26
Rep 660
PROcede REV3+OpenFlash "Custom DynoTune" //Vishnu PWM Meth kit//AIS Meth Tank//18" Forgestar F14//BridgeStone RE11//WaveTrac LSD n M3 Bushing//
KW V3 Coilovers//ETS 6.25" FMIC//MS Ceramic Coated 3" DPs//aFe DCI//M3 style body kits//HPF GEN2 Exhaust//Performance CF Trunk Lip//FFTEC walbro 450 inline pump kit// |
09-20-2011, 10:23 PM | #22 |
74
Rep 1,254
The mph is commensurate with the rpm. I ran out of space on the run... Not sur about the humidity difference but it wasn't 10% vs. 90%. They were the same stretch of road within a couple of weeks of each other.
