HELP NEEDED..Factory Amplifier wire harness pin
09-01-2011, 04:28 PM | #1 |
BimmerMan
9
Rep 126
I was making some modifications to my factory stereo wire harness connector that connects to the factory amplifier and I broke two of the wire harness pins.
Does anybody know where I can get the pins? I’ve checked a couple of junk yards but haven’t found any luck finding electrical BMW parts. 1st picture shows a better idea of what I am looking for 2nd picture shows what wire harness these pins belong to. Thankx Last edited by zfyusuf; 09-01-2011 at 07:05 PM.. |
09-01-2011, 04:33 PM | #2 |
BimmerMan
9
Rep 126
I found this on realoem, but i don't know which pin is what.....or even if it is listed there
http://www.realoem.com/bmw/showparts...91&hg=61&fg=15 |
09-01-2011, 05:33 PM | #3 |
687
Rep 6,845
Drives: 2018 Audi RS5 coupe
I can narrow it down
It's #7, 8, or 9
09-01-2011, 06:16 PM | #5 | |
687
Rep 6,845
I have 2 plugs that plug into the underseat subs If I'm not too much mistaken, they connectors look the same So if you want I can mail 2 for you and you can just solder them in, with some heat shrink Unless you want to get the plug alone and crimp it
09-01-2011, 07:00 PM | #6 |
BimmerMan
9
Rep 126
It is the same style connector as the under seat subs but just smaller. The subs use a bigger wire. So therefore those pins wouldn’t work.
I’m sorry I forgot to mention that the factory amplifier uses the same style pin but in two different sizes. The one that I am looking for is the smaller version and not the bigger. The bigger pins are used for the subs, power and ground, but I need the smaller ones that are used for the speakers. Thankx Kmarei for being so generous, means a lot since I’ve been beating myself about this whole situation that I put myself in. |
09-01-2011, 08:14 PM | #8 |
BimmerMan
9
Rep 126
thankx Technic,
i created the amp rack that i asked about in the last post, i'll be sure to post pictures later when i'm finished the part number you posted is for the smaller pins used in the wire harness for the speakers and not the larger of the two. correct |
09-01-2011, 08:18 PM | #9 | |
687
Rep 6,845
Let's just say you're not the first person on the forum to have done that You are right, the one I have matches the sub plug, not the speakers
09-01-2011, 08:21 PM | #10 |
2288
Rep 13,001
Yes...
