Abs dtc lights??
09-01-2011, 09:49 AM | #1 |
69
Rep 868
Abs dtc lights??
If I take my car to the dealer with dp\'s on to get brake problem checked will I have an issue???
I have cpo for another year and a half and I live in west palm beach Florida All suggestions welcome Thanks
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
09-01-2011, 09:56 AM | #2 |
161
Rep 7,377
depends on the dealer
09-01-2011, 10:00 AM | #3 |
36
Rep 708
I've got this same issue (ABS, DTC, BRAKE lights come on randomly and go away randomly).... Let me know what you find out! I'm just out of warranty....
09-01-2011, 10:01 AM | #4 |
69
Rep 868
My local dealers are Braman and vista, any body have friends at one of these dealers??
09-01-2011, 10:03 AM | #5 |
69
Rep 868
My lights came on this morning 8am as of now still on
I'll keep ya posted
09-01-2011, 10:09 AM | #6 |
153
Rep 3,730
Your SZL module (steering wheel angle sensor) needs to be replaced. Dealer charges $1300 if out of warranty. They also need to reprogam the DME. Had mine go out at 51K miles (brake light, DTC, ABS) the problem started with random lights that would go away, eventually they stayed on for good and I had it fixed. This could potentially be dangerous guys, the angle sensor will sense if the car is in a roll and can disconnect the battery relay.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-01-2011, 10:14 AM | #7 | |
36
Rep 708
09-01-2011, 10:17 AM | #8 |
153
Rep 3,730
There's a DIY in the DIY section that may help you out, however, I think it involves opening the steering wheel and messing with the ribbon tape inside there.
09-01-2011, 10:44 AM | #9 | |
133
Rep 4,764
Put in a good battery and it all went away. |
09-01-2011, 10:55 AM | #10 | |
36
Rep 708
09-01-2011, 10:57 AM | #12 | |
36
Rep 708
09-01-2011, 11:02 AM | #13 |
36
Rep 708
09-01-2011, 11:48 AM | #14 |
69
Rep 868
Read mine with jb4.... No codes
09-01-2011, 12:42 PM | #15 |
69
Rep 868
Back to normal all lights are off
09-01-2011, 12:42 PM | #16 | |
133
Rep 4,764
If based on the production date on your car, you are coming up on 5 years old, it may be worthwhile to replace the battery now anyway. Tischer BMW is local to me and I can get a new one for <$200 and then register it with the BT tool. You should call your local BMW parts dept to see what it would cost to pick one up. Install it yourself and if you don't have a BT tool, see if someone in the regional forum will allow you to use their BT tool. |
09-01-2011, 12:46 PM | #17 | |
36
Rep 708
09-01-2011, 12:48 PM | #18 |
36
Rep 708
09-01-2011, 01:55 PM | #19 |
69
Rep 868
I didn't fix it.... Yet it was random
09-01-2011, 02:50 PM | #20 |
153
Rep 3,730
Zasquatch,
Sounds like you have an identical problem to what I had....same error lights + my blinkers didn't work either. Started off intermittent then finally was full out on all the time. I would get it looked at, hopefully it's only the battery, but for me turned out to be the SZL *Edit - I could clear with the BT tool but they would pop back up.
09-01-2011, 03:07 PM | #21 |
36
Rep 708
Yeah I'm hoping that's not the case if it is I'll be doing some soldering... I have the 3 lights intermittent and when they are on, no abs, no hill assist, no dtc, no cruise... Blinkers work fine, which is why I'm hesitant to point the finger at the SZL, but with my luck that will be the problem.
09-02-2011, 07:33 AM | #22 |
36
Rep 708
Lights randomly turned off again this morning... Did a log with the AP to see battery voltage. Minimum was down near 12.2V, max 14.1V, average around 13.7V.
Does anyone have a log laying around that they could check their values to compare? |
