Funny readings from a wideband (Innovate LC-1) when on meth?
09-01-2011, 09:38 AM | #1 |
273
Rep 5,876
When I run with just pump gas the car is tuned to hit low 12s high 11s under WOT...when meth turns on (80/20 meth/water mix with two CM7 nozzles and a 200psi pump from coolingmist) this should inject about 900cc/min given pressure back on the nozzles with boost and the fact there are two nozzles to push liquid out of.
At the time it starts spraying I see the AFR reported on the widebands (I have two of them) 1-1.5 points leaner than when running just pump gas. I then went on and tuned the car to run 11.8-11.9 AFR with meth running and that was fine, I was happily hitting 11.8-11.9. Then I switched meth off and did a run and I see AFR richer at 10.5-10.8 running just pump gas. Why does this happen? Is the LC-1 giving me false lean readings on meth somehow? Which should I take for reference? Could it be that LC-1 is being thrown off somehow by introducing meth? I know that the sensor is fine, new kit installed 4 months ago and I've done tons of logging/tuning with it on pump gas...only when introducing meth in the mix and keeping all the other tuning parameters the same does it start to read leaner on meth than on pump Given everything I've read so far, if you don't touch the stoich settings on the wideband and leave them at gasoline 14.7 settings and then add meth to the mix, what "should" happen is that the wideband should report richer not leaner...what gives? Same exact thing happens with 50/50 washer fluid mix...weird |
09-01-2011, 10:25 AM | #3 |
65
Rep 1,708
Just guessing but if you are adding AFR ratios while tuning instead of lambda value then the back calc to lamdba would be leaner. Meth is like 9:1.
You can check this by logging fuel volume to see your apprx meth %. Not sure though. |
09-01-2011, 10:32 AM | #4 |
273
Rep 5,876
09-01-2011, 10:36 AM | #5 |
102
Rep 3,460
The sensors might be from the same company, but the software that runs them is different. Id have to think about it some more, but Josh is on the right path.
09-01-2011, 10:52 AM | #6 | |
273
Rep 5,876
Most online info indicates that the expectation is that the mixture will go richer on a 50/50 mix. But there's quite a few posts out there indicating that some ppl observe the same readings as I did (i.e. going leaner when meth/water turns on...and that the more water is introduced the leaner the mix that's logged) In any case, I'll try to see how stock widebands compare, easy enough to log both at the same time |
09-01-2011, 11:18 AM | #7 |
65
Rep 1,708
yeah, I'm not sure now. Entering 12:1 is .81 volts which would be constant. this is hurting my brain. Water shouldn't make much (or any) difference as the molecules do not separate.
09-01-2011, 11:55 AM | #9 |
28
Rep 488
Drives: 2008 335xi E90
Isn't one of the reasons to run richer (AFR < 14.7, or lambda < 1) at WOT is to allow the extra unburnt fuel to soak up some of the heat to prevent knocking? If so, then the meth (and/or 50:50 methanol:water) serves that function to soak up the heat. Hence, less fuel is needed so you end up running leaner with meth and/or meth mixtures.
09-01-2011, 12:02 PM | #10 | |
273
Rep 5,876
09-01-2011, 12:29 PM | #11 | |
102
Rep 3,460
Gasoline is replaced with your meth mixture. Being that the widebands are calibrated to read 14.7 stoic vs whatever 6.5/14.7 mixture you got in there. |
09-01-2011, 12:40 PM | #13 |
102
Rep 3,460
What makes you think it should be richer on meth? Meth is partially replacing the gasoline. Being that anything over 6.5 is considered lean on meth it would technically report leaner readings if calibrated for straight gasoline. I could be way off here, but thats how it makes sense to me in my head lol
09-01-2011, 12:49 PM | #14 | |
65
Rep 1,708
EDIT: it would NOT be .81 volts but instead this is multiplier to the stoic voltage, which I don't know what this is. Last edited by Joshboody; 09-01-2011 at 12:56 PM.. |
09-01-2011, 01:05 PM | #15 | |
102
Rep 3,460
Say 50 percent of your lambda is gasoline and the other 50 is meth. The computer is programmed for gasoline so you divide whatever number you get by 14.7 to get your a/f ratio right? Being that meth is 6.5, dividing the whole thing by 14.7 is inaccurate. 14.7 plus 6.5 is 21.2, divide that by 2 is 10.6 is stoich assuming equal burn. 1.00 lambda divided by 14.7 is 14.7 af 1.00 lambda divided by 10.6 is 10.6 af for that mix. Being that the computer is set to use 14.7 as stoich when actual is 10.6, it would show leaner readings. You can't think of lambda cause lambda and af are tied in, they rely on each other. If i request .81 lambda it will spit out a 12.1 af ratio, however that .81 also depends on what type of fuel your are using. |
09-01-2011, 01:18 PM | #16 | |
14
Rep 284
This may help a little
PROCEDE V5, AR CATLESS DP's, HELIX FMIC, ER CHARGE PIPE AND TIAL BOV, OHLINS ROAD AND TRACK COILOVERS, INJEN INTAKE, AWD TURBO UPGRADE, VISHNU PWM METHANOL INJECTION, AMS CATBACK EXHAUST, M3 FRONT SUSPENSION COMPONENTS,VOLK RE30 19X9F 19X10R W/ YOKOHAMA ADVAN AD08 265/275
09-01-2011, 01:21 PM | #17 | |
65
Rep 1,708
09-01-2011, 01:24 PM | #18 | |
273
Rep 5,876
09-01-2011, 01:31 PM | #19 |
273
Rep 5,876
Overboost, that's actually a great post! So it seems that the LC-1 is actually doing what its supposed to do, i.e. reading leaner than it really is as it is calibrated to pump gas at 14.7 stoich...the question is how to figure out the "right" AFR given a meth/water mix, amount of meth/water injected and the amount of gasoline injected...fu*king headache!
and then ALL that changes winter to summer with different "blends" and then yet again when running race gas such as MS109 that burns at 13.4 stoich, geez, i never knew this would be that complicated when mixing fuels... no wonder I'm getting backfires when on meth from running too rich (between shifts) as I've been adding more fuel to fight the perceived lean runs when in fact when you take into account what Overboost quoted above it might be actually too rich after re-tuning... i think the best approach, to make it easy, might actually be to tune it on pump gas for X AFR and then just run meth on top as it can't be leaner only richer and more safe than on just pump gas...the issue is monitoring/logging are all off, damn it It'll be interesting to see how the stock widebands log on/off meth |
09-01-2011, 01:40 PM | #20 |
65
Rep 1,708
I think everyone is getting confused. If you tune for 12:1 with gas your wideband will target the ratio, so you do not have to change anything to keep this ratio no matter the fuel used. If you want to know the actual AFR of the fuel used then you have to do some calcs. BUT the ratio of air to fuel will stay constant.
09-01-2011, 01:46 PM | #21 | |
273
Rep 5,876
I did tune 12:1 on pump gas so I expected AFR to stay the same...turned on meth, the gauge in the "instant" meth starts flowing goes leaner than what was setup on pump (lambda goes higher than on pump gas), and in the "instant" meth turns off it goes back to where it was tuned for on pump gas |
