Ferrari Brakes On My 335xi?
08-31-2011, 03:55 PM | #1 |
Rep 90
I've done some searching and havent found anything close to this, so my question is:
Do you think front brakes from a Ferrari 360 could fit on my 335xi? I have a buddy who put a BBK on the front of his 360, so he has the 4 piston calipers, pads, lines, & 13" rotors. What do you guys think? |
08-31-2011, 07:56 PM | #3 |
82
Rep 984
as much as i would like to say yes, i HIGHLY doubt it. a ferrari has a different wheel bolt pattern anyway so the rotors would not even fit on the bolts without a huge amount of modification. unless you getting them for free and have time to mess around and have the car apart i would say forget it
09-01-2011, 12:08 AM | #5 |
Freight Dawg
104
Rep 2,103
You migh not be completely SOL. It depends on some things. I know Ferrari uses Brembo. What I don't know what model they use. Brembo has two departments: OE and performance. If they got it from the performance division you might be in luck. Brembo will have a bracket and rotor if they use the same brake caliper for a BBK for the 335. It's a long shot but maybe.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
09-01-2011, 08:32 AM | #6 |
30
Rep 679
my friend has put the porsche turbo ceramic brakes on his m6 - Since I drove it Im a true believer ;]
335 - Öhlins//Swift//M3 front suspension//M3 subframe bushes//Quaife LSD//AR Design Catless//Forge Intercooler//Alcon BBK//Goodridge//AFE//RPI//Fenders - SOLD M4-Mineral Gray/Full Shakir Orange/DCT/M Ceramic/M Adaptive Susp. |
09-02-2011, 10:04 AM | #7 | |
Costco Member
42
Rep 75
Seriously - if you really need more braking power, get a big brake kit designed specifcally for your car.
2015 Sakhir Orange M4/6MT/Adaptive Headlights & Suspension/Tech Package
09-02-2011, 11:01 AM | #8 |
Rep 90
09-02-2011, 12:49 PM | #9 | |
Hellafunctional
37
Rep 426
"Big Red Kit" Static brake bias- 65% Front Torque- 7033F/3664R Stoptech ST-60/40 static brake bias- 63% Front Torque- 6880F/4176R If you can use off-the-shelf Brembo brackets and some shims for the pads, this could be worth looking into. Sources: http://www.6speedonline.com/forums/9...otor-size.html http://www.tceperformanceproducts.com/bias-calculator/ |
