What couplers for HPF intercooler?
08-31-2011, 10:24 AM | #1 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
I am interested in buying the HPF intercooler, but I really don't care for the stock couplers with the c-camps. So I was getting ready to order one unit with regular couplers but HPF does not sell any silicone couplers.
So, can anyone recommend a set of silicone couplers that I can purchase for the HPF intercooler? If not, I am considering the AMS unit since their size is pretty much the same as HPF, their end tanks are virtually identical and they do come with silicone couplers. Thanks in advance.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
08-31-2011, 11:26 AM | #3 |
1121
Rep 5,396
Thanks. Unfortunately, they only seem to have straight couplers.
08-31-2011, 01:03 PM | #5 |
1121
Rep 5,396
True!
08-31-2011, 01:29 PM | #6 |
141
Rep 2,604
Drives: G80 Comp XDrive
HPF is 815 cubic inches AMS is 720. Doubt there is any noticeable difference between the two, but I also doubt there is a noticeable difference between the stock couplers and silicone couplers, other than the ease of install and removal. AMS is great so go for that one if want one that comes with couplers. Otherwise if you contact Lutz and order the HPF through them, I'm sure they would include couplers for you, they just did a group buy not too long ago.
08-31-2011, 02:15 PM | #7 | |
1121
Rep 5,396
Yeah, I know about AMS being a bit smaller in volume than HPF. I do like both of their end tank designs. The dimensions are close with in each other too. The AMS unit comes with good couplers, but the HPF one comes with additional brackets for supporting it from below which I also like...
08-31-2011, 02:47 PM | #9 |
1121
Rep 5,396
Just called HPF directly to clarify things up a bit on the couplers. It is confirmed: if you want an intercooler without the OEM c-clamps, you need to source your own couplers.
Side note: I know this will probably cause a lot of people to laugh and be generally negative, but they told me that the HPF intercooler will OEM c-clamps will work with their Stage 1 single turbo kit. I was told that they are currently making a batch of the exhaust manifolds. They will be releasing it in 3 months and it will come with a new charge pipe which will connect to intercooler with OEM style c-clamp. It should be really interesting to see HPF will meet their own timeline: 3 months for Stage 1 single turbo.
