what suspension mod I need to match e46 m3
08-30-2011, 09:29 PM | #1 |
60
Rep 372
Hi guys, so i drove my buddy's m3 and my 335i back to back on some twisty roads the other day, I have stock SZP suspension btw, I have to say I am very disappointed about the suspension setup on my 335. the m3 feels so much tighter/more planted and much less body roll on twisty. Now I feel like a suspension upgrade so badly. So I am wondering how much improvement I should expect to see with a decent set of coilover/shocks+spring combo? and how well it will match a e46 m3 on corners? I am also thinking about m3 suspension bits upgrade however my budget will not allow me to do a coilover and m3 bits at the same time, which mod should i go with first? thanks for any input.
08-30-2011, 09:37 PM | #2 |
cool beans
63
Rep 1,364
you will find tighter and more accurate response with the M3 bits. That will tighten up the connection between you and the car.
The coilovers will give you a firmer stance with less bodyroll. I'd say for a more noticeable effect, do the coilovers first, since one of your complaints was the body roll/planted feel. Then worry about sharpening the tool. |
08-30-2011, 09:45 PM | #3 | |
127
Rep 6,773
08-30-2011, 09:49 PM | #4 |
17
Rep 363
I did coilovers first and the body roll went away. Put in KW series 1's and was very happy with the improvement. I have since put a Quaife LSD on the car, and in the month and a half since, I have not had the E-diff light come on once.
I was going to beef up the roll bars, but a lot of research revealed without the LSD, I might have issues with rear axle hop coming out of corners. Since doing the LSD I am not sure if I really need to do any more suspension mods. The labor to install a thicker rear sway bar is pretty high, and I don't know how much of an improvement it will be? |
08-30-2011, 09:52 PM | #5 |
127
Rep 6,773
Since you have an LSD you should also consider the M3 rear subframe bushings..that will help alot..you will need to drop the subframe..which is alot of labor..but the pro is you can easily swap out the rear sway and arms for the m3s..
It all depends on how much you r willing to spend.. |
08-30-2011, 10:12 PM | #6 |
60
Rep 372
thanks for the reply guys, i am now looking at either kw v1 or v2, and maybe just koni yellow/FSD+spring, I really don't think I need to adjust my ride height
08-30-2011, 11:36 PM | #7 |
cool beans
63
Rep 1,364
08-31-2011, 12:43 AM | #8 | |
164
Rep 2,556
Adding: I did the LSD first, then Koni dampers and wider non-rft tires and so on. To answer your last question: I'd do the M3 front control arms and tires first.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS Last edited by cvc 22349a; 08-31-2011 at 12:48 AM.. Reason: edit |
08-31-2011, 12:50 AM | #9 |
91
Rep 1,324
Drives: 335i Coupe, 6 Speed
You'll probably have to drop a bit of weight in addition to the above mods. The e46 Is 3400 lbs while the e92 is 3600.
08-31-2011, 02:37 PM | #10 |
Rep 68
08-31-2011, 02:39 PM | #11 |
127
Rep 6,773
DEF dont agree..LSD will shine in corners but another great advantage of the LSD is it puts the power down evenly on straights..you would be surprised how much power u lose on a straight w/o an LSD.. I have gotten on it in a straight only to have my cars ass flex around from side to side..all b/c of the open diff
08-31-2011, 02:45 PM | #12 |
164
Rep 2,556
200 lbs isn't a big difference. The biggest difference is the soft, excessive rubber in the suspension to soften the ride for the rft's and then the softer spring and damper rates.
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
08-31-2011, 03:04 PM | #13 | |
91
Rep 1,324
That's true. If he were to upgrade those bits and then dropped 200lbs on top of that, it would probably get much closer to the e46.
I can second the LSD. Having the LSD is a night and day difference in corners and makes a huge difference in a straight line, especially when its wet out. I still feel torque steer though because of the soft subframe bushings. Can't wait to get those swapped out. |
08-31-2011, 03:15 PM | #14 | |
127
Rep 6,773
Harold was really one of the main pioneers of this including the M3 bits..I have worked w him on all my suspension mods/ |
08-31-2011, 03:17 PM | #15 | |
164
Rep 2,556
08-31-2011, 03:22 PM | #16 | |
91
Rep 1,324
I know that these make the alignment much easier. What exactly do they do for the suspension geometry apart from an alignment perspective? From what I recall they were about ~$250, nothing outrageous.
08-31-2011, 03:45 PM | #17 |
164
Rep 2,556
They don't change the geomety; they keep the alignment from changing so much during hard cornering and acceleration. I just got an alignment, otherwise I get these. VM are more than $250; others are cheaper..
08-31-2011, 03:49 PM | #18 | |
127
Rep 6,773
Go with the Megan Racing one instead..I dont know if the bearing is as good as the VM..but its the only choice in town right now..Good thread here w Orb recommending them.. http://www.e90post.com/forums/showth...9#post10176599 |
08-31-2011, 04:02 PM | #19 | |
Rep 68
Not sure I understand what you mean about being on a straight. Are you saying you think it helps put down more RWHP? To my understanding, the LSD helps distribute power differently to wheels that have more grip. This would happen when someone is REALLY at their driving limits. I think 97% of the people who say they drive at the limit on twisty roads, really aren't driving at the limit. |
08-31-2011, 06:21 PM | #21 | |
127
Rep 6,773
It doesnt have to be at the limits but it doesnt have to be at the minimum either. |
08-31-2011, 06:56 PM | #22 | |
127
Rep 6,773
