Best way to get top end power?
08-30-2011, 01:34 PM | #1 |
68
Rep 743
Drives: FBO 335i
Ran a E46 M3 and they surprisingly have really good top end power (passed me in the twisties), but I'm running a tune and intake with some coilovers. What should I ideally get after downpipes, a BOV/DV or FMIC? I also hear that a BOV or DV will help stop some of the rattling noise.
08-30-2011, 02:42 PM | #3 |
127
Rep 6,773
Its the nature of turbos..N/A will have better power up top but keep in mind we rule when it comes to torque..which is what really counts..
DPs, Intake, full catless exhaust, FMIC, and ''proper'' tune will get u 400+HP and torque |
08-30-2011, 02:46 PM | #4 |
25
Rep 838
Do you know if the M3 has a tune? What tune are you running?
Your next Best upgrade is DP's and IC. You should walk even a modified e46 after these upgrades. |
08-30-2011, 02:47 PM | #5 |
51
Rep 923
DV/BOV will not add any power, and won't help with wastegate rattle. After DP's a FMIC or Meth is a good next step. Honestly though, you don't need anymore top end to run down a E46 M3. With a tune alone (assuming you are running a JB3/4, Procede, Giac, or COBB) you are way ahead in terms of power and should be outing running him without trying. The M3 has a better suspension though than a 335i with coilovers.
08-30-2011, 02:49 PM | #6 |
153
Rep 3,730
Meth
/thread
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
08-30-2011, 02:53 PM | #8 |
68
Rep 743
Drives: FBO 335i
Would meth be ideal if I plan on keeping my car for a long time? I hear it's not good for the turbo's longevity.
08-30-2011, 02:54 PM | #10 |
127
Rep 6,773
08-30-2011, 02:57 PM | #11 |
153
Rep 3,730
Where the hell did you hear that from? I guess you could make an argument that running meth will allow you to run higher PSI, placing more strain on the turbo, but in no way does methanol effect a turbo's logevity.
08-30-2011, 03:00 PM | #12 |
161
Rep 7,377
STage 2 turbos :-)
08-30-2011, 03:00 PM | #13 |
83
Rep 2,291
As far as top end power is concerned I would definitely go for the meth/intercooler combo. A DP is important but it is much more for responsiveness and spool time... Either way, definitely FBO + Meth will be the best options for top end power on this car outside of upgraded turbos.
2jZ + RB26 + 4G63 + LS9 + N54 =
08-30-2011, 03:04 PM | #14 |
25
Rep 838
Would be nice....however, I realize there may be some room under the hood after pitching the 2 hairdryers for the one big one. The reality is that the 42R's are massive, you could hollow one of those bastards out and raise a small family in one. What about injectors, fuel pressure, MAF voltage, custom tune, etc. These things need to be factored when making a massive HP jump. It isn't that cut and dry.
08-30-2011, 03:06 PM | #16 | |
25
Rep 838
08-30-2011, 03:26 PM | #17 |
33
Rep 1,177
Possible thread fail...sounds like a handling/driving prob versus powah
Get the E9x M3 suspension goodies and sticky wheels/tires and you will no longer 'lose 'im in the twisties'. |
08-30-2011, 03:28 PM | #18 | |
153
Rep 3,730
08-30-2011, 03:41 PM | #19 |
25
Rep 838
08-30-2011, 03:42 PM | #20 | |
3441
Rep 79,211
08-30-2011, 03:55 PM | #21 | |
35
Rep 450
to me the propper order would be TUNE, IC, DP's, then Meth. you will get more power doing the downpipes first but you will be running higher iats with the due to the higher power output and more boost from the tune. i'm no expert, this is just my gathered experience! |
08-30-2011, 03:59 PM | #22 | |
83
Rep 2,291
It is my personal opinion that you should do tune, intercooler, exhaust (including downpipes) and then meth but people will always have different opinions.
