keep blowing couplings
08-29-2011, 09:16 PM | #1 |
16
Rep 378
like title says...ever since I've upgraded to an aftermarket FMIC I keep blowing either the top coupling to the charge pipe or the lower coupling that connects to intercooler. Best way to solve this?
08-29-2011, 09:21 PM | #2 |
68
Rep 1,943
Did u install the small black clips that hold the radiator support, not sure Wa this is call. I didnt at first and my IC was kinda hanging low, the lower hose keep popping off, I put the clip back and problem solved. hard to explain
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
08-29-2011, 09:50 PM | #4 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Switch to T-bolt clamps.
08-29-2011, 10:28 PM | #6 |
127
Rep 6,773
I would caution against Tbolt clamps...they are in fact very strong..so strong that if you tighten to much you can crimp or break the piping which would def cause a leak...I am running over 16psi..and using only worm clamps w no issues..
Just go over each coupling and tighten..then go from there. |
08-30-2011, 02:09 AM | #7 |
68
Rep 1,943
No, the clips I'm taking abt are already on the car. U have to remove this in order to change the IC, I made the mistake of not installing 1 of them back and I keep causing 1 of my hoses to keep popping off.
08-30-2011, 08:04 AM | #9 | |
24
Rep 1,244
08-30-2011, 10:41 AM | #12 |
102
Rep 1,903
Drives: e92 335i 6MT
What IC do you have?
