Big Tom vs Other fast cars + Potential gearbox/clutch error
08-27-2011, 12:42 PM | #1 |
57
Rep 1,054
Bmw M5 E61 Eisenman Exhaust ESS Flash 545 hp:
Bentley Continental GT V12 BiTurbo 600 hp: Bad Flywheel: Bad Flywheel: Filmed from the M5: Last edited by Big Tom; 11-14-2011 at 05:33 PM.. |
08-27-2011, 01:36 PM | #4 |
247
Rep 2,567
Big tom, can you help tune my car??? Looks like you never loose! Good stuff!
07 e92 335i - Retired
18 F80 M3CS - Retired 21 G20 330i M-Sport - Current |
08-27-2011, 01:42 PM | #5 |
21
Rep 203
I had a similar noise a few months ago....but it just ended up being the heat shield rattle. You probably have something else going on since it goes away when you press the clutch. The noise I had was present regardless.
08-27-2011, 01:50 PM | #6 |
15
Rep 298
Sounds like a clutch throw-out bearing, had this problem in my 1997 M3 with a stock clutch.
2018 BMW M3 ZCP
1999 BMW Z3 M Coupe Turbo 2017 Ram Rebel 2015 Porsche Cayman S |
08-27-2011, 02:06 PM | #8 |
30
Rep 1,041
I honestly thought it would have been a lot faster than it appeared to be....
E92 335i 2008 Space Grey 6MT | Pure Stage 2 turbos | Motiv PI | Trueform Tech Intake | Quaife LSD | M3 Suspension kit | Öhlins Road & Track Coilover | DEFIVfab N54 diff lockdown kit | COBB PTF E85 Map | Fuel-It Stage 3 LPFP | NGK 5992 plugs | Wagner FMIC | Wagner 3" DP | Milltek exhaust | Tial BOV | SPEC Stage 3+ clutch | SPEC Steel SM Flywheel |
08-27-2011, 02:11 PM | #9 |
7
Rep 520
Hi Tom
Sorry about your clutch, weird it would give up with just a "small" amount of abuse You plan on getting the Act clutch from the US or have you found an European dealer? going with a lighter flywheel as whell? On one af the rewievs here from a clutchmasters, I could see in a picture it said Sachs on it, but if you visit their homepage they don´t listen anything above 500nm |
08-27-2011, 02:23 PM | #10 |
69
Rep 1,137
Wow, I am very suprized at the Bentley. I was thinking of picking a used one up to play with, but now I'm second guessing that.
Hey Big tom what Boost are you running? Stock Turbo's? Sounds like throw out bearring. That is exactly the way it sounded on my Eclipse when they went bad. I had 3 go bad.
2008 335i coupe AW 6AT, RB Turbos, PROcede 2.5 V5, Alpina Flash, Injen Intake, VK MW DP . Helix IC, Vishnu PnP Meth(M10 nozzel), M3 sides, OEM Aero Lip, VMR V710 Midnight Blue, LUX H8, HID Fogs, M3 front bits, D2 Coilovers, Whiteline Rear Bushing inserts, Custom M3 Steering Wheel, Cyba scoops, M2 Performance Exhaust |
08-27-2011, 02:46 PM | #12 |
29
Rep 1,551
I just had my tranny replaced 5000km ago. My car makes a much milder form of the same noise you are experiencing. I think the dual mass flywheel springs are not toleranced correctly.
08-27-2011, 02:53 PM | #14 | |
57
Rep 1,054
08-27-2011, 03:05 PM | #15 | |
57
Rep 1,054
08-27-2011, 03:07 PM | #16 | |
7
Rep 520
But since sachs suplies the clutches for clutchmasters I shold be possible to have´em pech one here in Europe?? |
08-27-2011, 03:07 PM | #17 |
57
Rep 1,054
08-27-2011, 03:13 PM | #18 |
3441
Rep 79,211
Could be the springs on the clutch. BMW is notorious to have them go. Not sure about the e90 platform but definitely on the older E30 E36 ETC
08-27-2011, 03:28 PM | #21 |
57
Rep 1,054
08-27-2011, 03:32 PM | #22 |
83
Rep 2,291
Nice run against the Bentley but that beast weighs 5200 lbs lol, my Touareg SUV weighed quite a bit less than that and that was already a heavy car.
2jZ + RB26 + 4G63 + LS9 + N54 =
