Red car on lift reset
08-27-2011, 03:26 AM | #1 |
19
Rep 410
Guys,
So a couple weeks ago my front sensor got unplugged, I didn't change it for a couple weeks and the "your pad is wore to minimum" and the red brake light in the cluster were up for that time. When I went to change everything, my brakes were good and rotors were good as well. I replaced both sensors and proceeded to do the reset Reset went thru for front and red ....HOWEVER.. It did not get rid of the red car on the lift, drive message and brake light on cluster. For what I was reading there are some people saying that if you run with the code for too long only a bt tool or the dealership can get rid of it..I can't afford neither of both.. Questions : Will a CAN cable (the one used for coding) will be able to get rid of this code?If so..with what software.? Is there anye other tool that is not bt nor in that price range that can be used to get rid of it? Is there any solution that you guys recommend ? Anyone had this experience before? Saw a couple of threads about this ..some saying an ecu upgrade is necessary, others saying different Thanks in advance ! |
