Can NOT hit target boost. please read me lol.
08-26-2011, 10:17 PM | #1 |
40
Rep 957
Have installed PWM vishnu meth kit about 3 weeks ago. Have reviewed all of our steps and all appear just fine. ONE night, the second night driving the car, it spiked to 18lb consistently. The first night running it, it would not, and since then WILL NOT. We have been trouble shooting every possible idea but are left stumped. Not able to enjoy my new meth kit and its just been a tease and headache. Any help or ideas from anyone with any similar problem as this would be greatly appreciated... My meth lights DO come on and stay on properly. Meth is flowing fine. Map 4 parameters set as follows
7-29 maps and v5.2 Max boost: 18 Start boost: 75 (17.5) IC: 0% Meth mode: 1 Autotune: OFF Injection Mode: 20 Using M1 methanol and distilled water at about 75/25 ratio 93 octane fuel always. I am spiking at 16 right now tops.. No explanation as to why so i will now post what we have troubleshooted... Things we've investigated/troubleshooted 1) Switched from stock bypass valves to my forge dv's AND to a friends forge dv's. Makes NO difference. So its not a matter of holding boost pressure or leaking there. The second night i had the kit when it WAS boosting right, it felt great, and i was actually using the stock bypass valves. 2) No boost leaks.. Checked every clamp, everything is on properly and snug and the clamps are tight as hell. Even went as far as to have car smoke test at the stealership..yes. And as i suspected, no leaks. Vacuum lines are good 2 go as well. 3) Was getting 3 codes related to throttle body which struck an SES , but those are no longer appearing at this point. Tested throttle body with bmw program and manually opened throttle body 50 and 100% and it worked perfectly so.. 4) Robert sent me a Rev 2.5 procede which i put in the car today. This was taking a shot at it possibly being a freak issue with my procede. nope. car spiking at just barely 16psi still. 5) Swapped my friends harness into my car. Car still ran the same.. I guess not a harness issue... Really could use some input at this point.. Why can i not hit the targets i am set at? Having no luck. thanks guys. any help would be nice.
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle Last edited by plague; 08-26-2011 at 10:36 PM.. |
08-26-2011, 10:30 PM | #2 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Are you sure your meth kit is properly powered?
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
08-26-2011, 10:32 PM | #3 |
40
Rep 957
well, lights come on, meth sprays etc. so it would appear so.
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle |
08-27-2011, 08:21 AM | #5 |
184
Rep 2,841
After that very thorough process of elimination, the only things that come to mind might be the TMAP sensor itself being borderline, or the wastegate solenoids.
Those are all easy enough to swap out and are just another step in the chain of boost control. Nice that Vishnu stepped up to the plate and sent you another procede |
08-27-2011, 09:13 AM | #6 |
112
Rep 4,771
I do want to mention that starting boost of 17.5 and max boost of 18 doesn't give you a very big range. I thought you were always supposed to give yourself at least 1 psi range
08-27-2011, 09:31 AM | #7 |
13
Rep 377
+1..also if you autotuning off, it should never boost above your 17.5 setting anyways
2007 335i Coupe 6AT - Sports Package - Premium Package - Procede V5 Rev 2.5 - Vishnu PWM - Vishnu DCI - Vanguard Exhaust - AR Downpipes - Helix FMIC - 19" Avant Garde M6 Reps - Michelin Pilot Super Sports - Bilstein PSS10 - M3 Suspension Bits - M3 Sway - M3 Strut Brace - GP Thunder -Forge DV -15% Tint - Aero Lip
08-27-2011, 10:52 AM | #9 |
40
Rep 957
with autotuning off its not much of a matter i believe. im using fuel gauge (procede) as my gauge. its very accurate, has been for me at least. its not in my mind either, car feels no faster than pre meth right now. for the night when i was spiking to 18, there was a major difference in the butt dyno.. no mistaking in peeling through the first two gears and a tad of third. we do have some logs recorded as well. theyre posted in my other thread i could post them in here.
08-27-2011, 11:11 AM | #10 |
112
Rep 4,771
I agree that wouldn't be the cause of your problems. If the Procede went into some kind of safe mode or valet then boost would be far less than 16 psi or so.
Does the meth kit communicate with the Procede so that the tune doesn't allow full boost because of a lack of adequate meth flow? Maybe something is impeding flow... other than that, I have no idea what is wrong. |
08-27-2011, 11:11 AM | #11 | |
13
Rep 377
when it comes to power..autotuning can increase the power, as it will move boost and ignition up..with it off...you wont boost over 17.5 period...unless during an upshift it might spike above that for a split second, but you will not continue hit 18 throughout the rpm range because 17.5 is where you have it set. it will only go higher than that if you have autotune turned on, and even then it wont boost any higher than 18 since thats your max..hope you can understand what im saying!!!
08-27-2011, 11:27 AM | #12 | |
40
Rep 957
08-27-2011, 11:59 AM | #13 | |
40
Rep 957
08-27-2011, 12:00 PM | #14 | |
40
Rep 957
08-27-2011, 01:02 PM | #16 |
3441
Rep 79,211
I think you are all looking at the wrong things.
Logs of Wastegate duty cycle would help.... the PROcede will only push the wastegate a small extra percentage to try to hit target and for safety reasons wont push any further. It sounds like you have a boost leak if your not hitting target. Smoke tests are irrelvant as they offer no positive pressure. A leak at 0 PSI is different then a leak at 15+ PSI and that wont be found unless your smoke test is providing a 20+ PSI pressure test. You should change your boost max to 18.5 PSI also. Edit- You problem could also be the wastegates themselves. Last edited by Jeff@TopGearSolutions; 08-27-2011 at 01:09 PM.. |
08-27-2011, 01:29 PM | #17 | |
40
Rep 957
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle Last edited by plague; 08-27-2011 at 01:36 PM.. |
08-27-2011, 04:06 PM | #19 | |
40
Rep 957
to boost that high? car has 23k miles btw. even on map 1 im boosting lower than target. odd. and the fact that it boosted right one day and then hasnt since, odd as well. i will get WGDC logs when i get a chance. thanks jeff, im not the most car technical guy but am learning all i can. so the help is valuable for me.
08-27-2011, 06:25 PM | #20 |
164
Rep 2,875
Were you boosting ok without the tune?
Also you mentioned not boosting enough after loading the 7-xx maps.....have you tried loading the earlier maps and see if the boost is up to target?
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
08-27-2011, 06:28 PM | #21 | |
3441
Rep 79,211
I find D not be the case as much as the others considering everyone else hits targets just fine. These wastegates are primarily known for sticking but usually with more mileage. |
