Need Better Brakes Pads than Hawk HPS
08-25-2011, 04:59 PM | #1 |
42
Rep 226
I just put on some centric rotors and Hawk HPS pads but it definitely doesn't feel like OEM, it actually feels a lot worse. I did the bedding in process twice but it still doesn't have that initial "bite" like OEM. I thought I was upgrading with these. Basically im looking to keep the same rotors but upgrade the pads to oem or better, I'm not too concerned about brake dust.. just want that braking power back. Thanks for any suggestions.
08-25-2011, 05:35 PM | #2 |
164
Rep 2,875
Why don't you just get the OEM pads then?
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
08-25-2011, 06:26 PM | #5 |
Freight Dawg
104
Rep 2,103
Try stoptech street performance pads. Cheap and OE-like. The do squeak a little. If you want more heat resistance go with Hawk DTC-70. 335 owners have trouble fading them on the track.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
08-25-2011, 06:45 PM | #6 | |
81
Rep 1,510
08-26-2011, 04:00 AM | #7 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
If you are looking for more performance, but is not ready for a track pad, Ferodo DS2500's fills that void very well. |
08-28-2011, 10:52 PM | #8 |
106
Rep 1,428
i had that same setup on my previous e90, i liked it alot. you are right there isnt as much initial bite, but the hps hold longer in hard braking. i had multiple 100+ to 20mph slow downs with the exact setup. when these pads heat up they work better, i just bought a 2011 335, and if it were not for warranty i would switch to the hawk hps, but this time i would stick with oem rotors. in my opinion the centric/stoptech product is garbage.
