Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > DME warning...
      08-24-2011, 09:52 PM   #1
335i101
335i101's Avatar
Drives: 2008 E60 M5
DME warning...
Recently my car started surging and was undrivable...I was in northern WI and no dealerships anywhere. I had it towed 220 miles to my local dealership.---insurance covered it
After there inspection they said I needed a new DME and with parts and labor it was $1900.00. I had my suspicions and had tje car towed toy house.
Ran some tests and found it was a blown fuse in the ECU box, replaced and car is running perfect.....just a heads up to all!
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2008 M5 with muffler delete-sold
2007 650i-sold
2008 335i-JB4, DP, Meth-sold
      08-24-2011, 09:56 PM   #2
cwn23
23
Drives: E92
Can you elaborate on what blown fuse you are speaking of which caused your car to surge and undrivable?
      08-24-2011, 10:02 PM   #3
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Wow. Nice move!
      08-24-2011, 10:21 PM   #4
335i101
335i101's Avatar
Drives: 2008 E60 M5
I was driving up north in tje middle of nowhere....I went WOT and heard a loud "pop" tje car immediately started surging and was undriveable.
First I checked all the fuses in the glove box and they were good...then there were 2 fuses in the ecu, both good...about the time I was ready to give up I located 5fuses packaged together in the ecu compartment....one of those 30amp fuses were shot.
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      08-24-2011, 10:51 PM   #5
EastBayE90
Formerly (-(ellblazer420
EastBayE90's Avatar
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
Nice find so that fuse image I gave you worked out congrats nice save!
(410whp 445ft/lbs | DCI + Meth Only)
OpenFlash OTS Stage 1 Flash | Vishnu PWM Meth Kit | Vishnu DCI| Forge DVs
      08-25-2011, 08:30 AM   #6
hotrod182
hotrod182's Avatar
812
Drives: 2023 i4 M50
Wow, 30amps would be a major amperage short for the DME. What else is on that fuse circuit?
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra,
2008 Black 335i Sedan. 11.11@ 129.47 mph
2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds
2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy)
      08-25-2011, 09:09 AM   #7
secretsquirrel
secretsquirrel's Avatar
130
Drives: f80
Be sure to let the stealership know what really happened. They don't call them stealerships for nothing.
      08-25-2011, 09:31 AM   #8
cwn23
23
Drives: E92
+1 There has to be something that caused the fuse to blow in the first place...30 amp fuse to blow cant be just from being an old fuse!
      08-25-2011, 12:27 PM   #9
lonestar22
Ground Clearance?
lonestar22's Avatar
Drives: 540i & X5
yeah im pretty sure it blew because something is wrong. thats why the dealer recommended replacement
E90 330i - E90 335i - E92 335i
      08-25-2011, 05:59 PM   #10
335i101
335i101's Avatar
Drives: 2008 E60 M5
The fuse blowing was a fault of my own, a wire nut came off from my meth setup and shorted out. I told the stealership I had a meth setup.
(although I removed it before it was towed to them as I was trying to fix the car prior to the tow...)
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      08-25-2011, 06:15 PM   #11
335i101
335i101's Avatar
Drives: 2008 E60 M5
not sure what is all connected to that fuse but I got low battery, traction control, abs, and "!" warning lights.....after fuse was replaced, I cleared codes and all is good.
Here was the fuse compartment in ECU area....
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      08-25-2011, 06:41 PM   #12
cwn23
23
Drives: E92
It must have been so nice to find the issue after all those hours of you trying to get it working! Kudos to you brother
      08-27-2011, 11:40 PM   #13
caliguy562
8
Drives: E92 335i
Can you tell me exactly where those fuses are located in the ECU compartment. I can't find them, but maybe it's because I have an '07. Either way, currently I'm having the same issue.
      08-28-2011, 12:04 AM   #14
335i101
335i101's Avatar
Drives: 2008 E60 M5
PM sent, let me know if that was the issue...I will sleep better knowing I saved someone 2k!
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      08-28-2011, 06:53 PM   #15
blueaudi18
blueaudi18's Avatar
Drives: e92 08' 335i , mb sl500
Wished i found this post ealier.. car at dealer getting ecu replaced caue waterpu wont turn on.. my bill is 2700 though.
POSTED WITH APOLOGIES FOR POOR SPELLING, GRAMMAR AND SENTENCE STRUCTURE
      08-28-2011, 11:08 PM   #16
3coupe
3coupe's Avatar
31
Drives: BMW 335i Coupe 07
are we talking about the dme in the engine compartment? i can't find where this ecu box in the above picture is located
BMW E92 335i
retired: 04 BMW M3 | 05 Honda S2000 | 03 BMW 330ci | 01 Honda Prelude | 99 Acura Type-R
      08-29-2011, 12:46 AM   #17
caliguy562
8
Drives: E92 335i
335i101, I owe you a beer or something. Actually my car didn't have those five fuses in the ecu box. Under the black cap was a relay. BT tool pointed to the dme main relay. However, I know relays don't fail without warning. I found a blown 30 amp fuse behind the glove compartment. Replaced and car fired right up.
Thanks again for your quick response..def helped me get some rest before I got back to it this morning.
      08-29-2011, 01:50 AM   #18
335i101
335i101's Avatar
Drives: 2008 E60 M5
I have an 07' and it is located in the ecu box, more towards the center of the car, hidden under wires.....it does not look like a fuse box, u need to look closely.
Also, as noted in latter post, the blown fuse may be in your fuse box (in the glove box) depending on model.
Anyway, if u get a ton of fault codes (along with reving engine and lots of orange warning lights) and one of the fault codes is the DME main relay, check ALL 30amp fuses and this is most likely the problem.
20 cents at the store or 2k at the dealer...
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      09-14-2011, 11:13 PM   #19
335i101
335i101's Avatar
Drives: 2008 E60 M5
Bump for recent post
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
      03-25-2012, 11:04 AM   #20
HGreen335
HGreen335's Avatar
34
Drives: N54 335i, S65 M3
having similar problems with my ecu. How do i get the cover off that black clip that has the fuses in it? i dont need to break something else
      03-25-2012, 12:20 PM   #21
Randomaccess335
Randomaccess335's Avatar
69
Drives: 07' 335I
My DME just went out, common for some 2007's. Dealer said it also took out all 6 injectors and coil packs.
DME code 30BB searched and found its possible bad diode
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets,
Ebay 4" chrome Tips, Lux Angel Eyes
**********11.910 @ 117.09***1.851 60'**********
      03-25-2012, 12:29 PM   #22
asado111
56
Drives: BMW M4
my dme went out before, it was close to a 1900 dollar bill, dealership replaced it under CPO, they replaced dme, all coils, spark plugs, and fuel injectors.
