Replace my own Logic 7 amp?
08-23-2011, 11:16 AM | #1 |
Rep 2
Hey all. We were out camping with our 335i and had a 2.5 gallon water container leak its contents into the trunk. It seems to have fried the amp (no chime on startup, no music, no sounds).
Additionally, the Sat receiver no longer registers with the head unit and I'm getting an SOS failure. I haven't pulled the trunk apart yet, but I suspect there's a sat receiver in there that's toast now, too. I've been poking around here with various searches, but haven't found anyone with my level of misfortune and/or stupidity yet. So, the questions: 1) If you've had either of those components fail, do my symptoms seem to be in line with what others have experienced. 2) Are there model specific differences in the L7 amp? Or do multiple models share a common part number? 3) When replacing either of these components, is some sort of re-integration with the rest of the car's network required? If so, can it be done by a fairly skilled DIY? Thanks, guys. I've been lurking here for a couple years, but this is my first post. |
08-23-2011, 12:18 PM | #2 | |
2288
Rep 13,001
Replace the OEM amp (no coding required as long as it is used) and most probably the error will clear and you will get all sounds back. Of course, if something else got messed up then you will have to replace more modules until the ring is re-established. |
08-23-2011, 12:37 PM | #3 | |
Rep 2
Thanks, Technic. This is hugely helpful. I have a couple BMW motorcycles with CanBus, so it sounds like the automotive systems work similarly. Are amps model specific? More clearly, I can't figure out whether I need to buy an amp that is from my exact model or not. Thanks again. I really appreciate the help.
2008 335i Sedan
Some BMW bikes |
