lean-burn maps
04-20-2007, 11:19 PM | #1 |
25
Rep 122
lean-burn maps
e90fleet,
do you think it's possible bmw would update older version 335i's ecu software in a dealership flash in the US when we get the low sulphur fuel to make use of the lean-burn maps? or would there need to be some sort of hardware update to make it work? what exactly are the benefits of the lean-burn map? just increased economy/lower emissions? thanks!
__________________________________________________
Future ED Car: E92 335i Montego Blue w/ Black leatherette and Grey Poplar Sport Package, Navigation, Bluetooth, Sunshade, Heated Seats, 6 mt BBS RG-Rs |
04-21-2007, 02:12 AM | #2 | |
38
Rep 762
Where did you hear this? I just want to make sure we're talking about the same thing. |
04-21-2007, 03:20 AM | #3 | |
1312
Rep 10,185
Thats the reason the normal DI engines arnt being released outside europe yet, because it requires the correct fuel. The 335i had the maps removed for countries without the correct fuel, but for the smaller engines, its cheaper to just fit the uprated N52KP than fit the new DI engines without the lean burn maps.
BMW if you are reading, I need a job, Please. |
04-21-2007, 03:22 AM | #4 | |
1312
Rep 10,185
I dont know if they will be able to activate it later
04-21-2007, 04:58 AM | #5 | |
38
Rep 762
2007 Engine Technology Page 10. (unless I misunderstood it) • Stratified Mixture Formation - In the stratified injection method, a homogeneous mixture is only created around the area of the spark plug. A lean (inhomogeneous) mixture exists in the rest on the combustion chamber. Therefore the overall A/F mixture in the combustion chamber is lean (lambda > 1). This results in increased combustion chamber temperature, and subsequently increased NOx emissions. The increased NOx requires the use of a DeNOx catalyst which is not effective when sulfur is present in the fuel. Therefore, sulfur free fuel must be used which is not readily available in all markets. For the time being, BMW does not have any engines which operate as “stratified charge” engines. |
04-21-2007, 06:08 AM | #6 | |
1312
Rep 10,185
2) The lean burn non-turbo engines have only been released recently as 08 models 5 Series and 1 Series and only in Europe ( others get a N52KP ). New European 330i and 325i Convertibles also have it The mainland europe 335i was supposed to have it since introduction as far as I know. Picture from Facelift 1 Series press release:
