2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions How to remove 535xi emblem from trunk?
      08-21-2011, 04:02 PM   #1
Chinoxblu20
Drives: 2014 535xi 'White on White'
Trying to take the 535xi from the truck and heard all the types of ways to accomplish this but want all your safest way in doing this workouts marks on paint! Thanks
      08-21-2011, 09:29 PM   #2
mspeasl
Sixties Drag Racer
mspeasl's Avatar
Drives: 2011 Cashmere Silver 528i
Dental floss
Dental floss works wonders
Mspeasl - Central Illinois - USA :
My Garage: 2011 - Cashmere Silver Metallic BMW, 528i (Delivered 17 January 2011)
2008 - Radiant Red Toyota, M6 'X-Runner' (Delivered 15 November 2007)
1957 - Chevrolet Bel Air 2dr Coupe' Drag Car (2nd Owner since 1964)
1947 - Chevrolet Sport Master Coupe' Street Rod (2nd Owner since 1974)
      08-22-2011, 01:39 PM   #3
Chinoxblu20
What about the 3m sticky how do I remove that?
      08-22-2011, 04:13 PM   #4
Lonestar5
Drives: 2011 535i
Once I got the badge off I put some goo-gone on the adhesive and let it sit for a little bit. By the time I got to the last 5 and i it came off like butta. Did a final wipe down and polished and sealed the surface.
      08-22-2011, 05:23 PM   #5
Sonnie
Bama Hillbilly
Drives: 2011 BMW 528i
Probably asked and answered fifty-eleven times, but why are you guys removing the badge?
      08-22-2011, 08:54 PM   #6
mspeasl
Sixties Drag Racer
mspeasl's Avatar
Clean look.........
      09-09-2011, 08:08 PM   #7
PR_F10_535
PR_F10_535's Avatar
Drives: 2011 f10 535i
What did u use to seal the surface?
      12-09-2011, 01:33 PM   #8
RespectTheGC
RespectTheGC's Avatar
Drives: 2014 BMW 640xi GC
step 1: with a hair dryer heat up the numbers. Moving the hair dryer back and forth across 3 letters at a time, heat for 10 seconds, then dont apply heat for 10 seconds and repeat a few times. You do not want to burn the paint!
step 2: After about 1 min, use fishing line or dentil floss. Start with the corner of a number or letter and keep pulling to the left or right(depending which side your starting on). Keep adding heat then taking it away and eventually the line will start sliding across the rear of the numbers.
step 3: you are now left with double sided tape residue. I like to use bug and tar remover. Spray it on. Wait about a minute. Try to pull off the big chunks if u can with ur fingers. THen with a soft cloth wipe the rest away.
step 4: put bug and tar remover on again. Wait 1 min. Wipe it off. Your car now looks like it never had numbers in the first place.
step 5: take pics.
Search this Thread:
Advanced Search
5post
