Multiple bulb warnings but no blown bulbs... Help!
08-19-2011, 11:23 AM | #1 |
18
Rep 162
Just got in my car to go home, stopping by BMW to pick up my new grilles, and Iv been given four bulb failure notices.
3 Indicators and a Front fog lamp. Stopped the car and checked and weirdly all of the bulbs on the car are working! The indicators when used are flashing like mad as if a bulb has gone but they flash at normal speeds when the hazard button is used. Gave the key to the service department at the garage and they couldn't suggest anything and have booked the car in for next week. Does anyone know what's caused this as if I can I want to sort this out over the weekend so I still have a car to use! |
08-19-2011, 12:07 PM | #2 |
Brotographer
88
Rep 1,741
Pull the negative terminal on the battery, wait a few minutes, and connect it back again. Perhaps the computer is just in a fuss.
Have you upgraded any of your bulbs to LEDs? |
08-19-2011, 01:42 PM | #4 | |
18
Rep 162
Well after a bit more digging iv now found a bit of odd behaviour.
The two lower bulbs that make up part of the sidelight on the rear passengers side aren't illuminating. Turned everything off and checked with a voltmeter. When turned on they have a voltage for a few seconds and then it dies again. The bulbs themselves are fine and Iv checked the relevant fuses and they all seem ok too. The indicators are flashing on double time (like they do when a bulb is gone) but all the bulbs are working. Im thinking it has to be something to do with the voltage drop on the two lower bulbs at the back. The fact that they power up but then go again to me suggests some sort of control fault. The brake light (which uses one of afore mentioned bulbs) is also working on the side with the problem Quote:
Nope not changed any of the bulbs Ill go try it now, thank you |
08-19-2011, 02:19 PM | #5 |
18
Rep 162
Disconnected the battery and left it 10 minutes, unfortunately the fault is still there.
Went into the check control and held the button to get the codes and go the following: 114 116 118 119 There were 2 digits before it but I cant remember them. Anyone able to shed any light? |
08-19-2011, 03:43 PM | #6 | |
Brotographer
88
Rep 1,741
AFAIK, the FRM is responsible for the lighting system in our cars (so, bulb-check, auto-leveling the Xenons, engaging the cornering bulbs, etc.) I'm wondering if your FRM may need to be recoded or replaced. Since it happened suddenly, I'm willing to bet that, if the FRM is indeed the culprit, it will need replacement. If your car is under warranty, it should be covered. |
08-19-2011, 05:37 PM | #7 | |
18
Rep 162
What's the damage to the wallet of one of these units? |
08-19-2011, 06:57 PM | #8 |
Brotographer
88
Rep 1,741
08-19-2011, 07:00 PM | #9 |
18
Rep 162
08-22-2011, 04:42 PM | #11 |
18
Rep 162
Well had one last ditch attempt at this before the car goes in tomorrow.
Found 2 of the electrical rails on the bulb holder in the boot lid had gotten too close. Quick adjustment and now all is good again |
