Which braided hoses
08-14-2011, 09:55 AM | #1 |
THE DIESEL WEASEL
26
Rep 304
Drives: BMW 330e
Which braided hoses
guys a while back I uprated my brakes for my 320d, by fitting brakes from a 335d with larger discs and callipers. Now I got a brake fluid service due, the issue with the brake upgrade is the 320d brake hoses are slightly short and a too snug fit on the larger brakes, which hoses are advised as a good replacement Goodridge or Hel and 4 or 6 line??? bit confused on this. Just wanna make sure I order the right part. Does dealers also use decent brake fluid, any know to use ones provide by the customer I rather have some motul rbf600 etc.
THE TURK....
08-14-2011, 12:44 PM | #2 |
LSD - No, you're not seeing things
72
Rep 3,302
Have used both - they are virtually the same construction, SS braid over a PTFE liner and crimp fittings.
Either will be fine, but remember to order the lines for the 335d and hope they fit Motul RBF600 is good for an all round use, they will fill with whatever you like normally. Buy it from Opie Oils and save some money....
