Help - running center channel speaker wire
08-13-2011, 07:58 AM | #1 |
255
Rep 2,547
For those with experience adding a center channel (I am adding ms-8 to my hifi), what is the best route to run the new speaker cable? I will be running it from the stock amp location in the trunk to the new center channel speaker in my dash. What has to come out of the car? Seats, carpet?? Thanks!
08-13-2011, 08:28 AM | #2 | |
2295
Rep 13,001
- remove cupholders - insert speaker wires thru the center speaker mounting hole - look thru the cupholders mounting holes, you are going to see the speaker wires - open glovebox and remove the fuse panel cover trim and the panel trim under the glovebox (where the passenger footwell light is) - keep inserting the wires while directing them to the back of the glovebox where the fuse panel is, you will see the wires there - grab the wires thru the glovebox fuse panel opening and pass them thru the top of the footwell towards the plastic trim on the right side of the footwell. - tuck wires in thru the doorsill trim all the way to the trunk. No need to remove the door sill trim - the rear seat bottom needs to be removed to ease the pass of the wires to the trunk, just grab the front of the bottom and pull up. |
08-13-2011, 02:15 PM | #3 | |
255
Rep 2,547
08-13-2011, 02:18 PM | #4 |
688
Rep 6,845
Drives: 2018 Audi RS5 coupe
Make sure you have a lot of band aids on hand
Must have cut my hand in at least 7 places when I did this But I didn't have Technics DIY instructions then I ran it straight down the center of the car Where all the nice sharp jagged bits are
08-14-2011, 04:57 PM | #5 | |
255
Rep 2,547
08-14-2011, 06:10 PM | #6 | |
2295
Rep 13,001
08-14-2011, 10:44 PM | #7 |
255
Rep 2,547
08-15-2011, 05:58 AM | #8 |
2295
Rep 13,001
08-15-2011, 06:29 PM | #9 |
96
Rep 831
There's some pics in my guide on how I did it. It actually fed through quite easily and the trim removal wasn't too hard either
F31 335d M Sport XD - Mineral Grey - Coral Red - 19" 442M - HK Audio - M Sport Plus Pack - Heated Seats Check out my E90stereo install guide - http://www.e90post.com/forums/showthread.php?t=540954 |
